What is your server bottleneck...storage, processing, expansion? The world's best-selling server just got better. The HPE ProLiant DL380 Gen9 Server delivers the latest performance and expandability. Reliability, serviceability and near continuous availability, backed by a comprehensive warranty, makes it ideal for any server environment. Deploy the data center standard. Designed to reduce costs and complexity, leveraging Intel's latest E5-2600 v4 processors with 21% performance gain, plus the latest HPE 2400 MHZ DDR4 SmartMemory supporting 3.0 TB and up to 23% performance increase. Supporting 12 Gb/s SAS, 40 Gb NIC with broad range compute options. HPE Persistent Memory, the world's first NVDIMM optimized on ProLiant, offering unprecedented levels of performance for databases and analytic workloads. Run everything from the most basic to mission critical applications, and can be deployed with confidence.
Flexible Design Makes Your Investment "Future Proof" so it Can Grow as Your Business Needs Expand
The HPE ProLiant DL380 Gen9 Server has a flexible redesigned chassis, including new HPE Universal Media Bay configuration options with 8 to 24 SFF and 4 or 12 LFF drive options along with NVMe options and additional rear drive support for expandability and investment protection.HPE Persistent Memory, the first Non-volatile DIMM (NVDIMM) optimized on HPE ProLiant, offering unprecedented levels of performance and data resiliency for databases and analytic workloads.In conjunction with the embedded SATA HPE Dynamic Smart Array B140i Controller for boot, data and media needs, the redesigned HPE Flexible Smart Array and HPE Smart SAS HBA Controllers allow you the flexibility to choose the optimal 12 Gb/s controller most suited to your environment.You have a choice of embedded 4x1GbE, HPE FlexibleLOM or PCIe standup 1GbE to 40GbE Adapters provide you flexibility of networking bandwidth and fabric so you can adapt and grow to changing business needs. -
World-class Performance and Industry-leading Energy Efficiency
The HPE ProLiant DL380 Gen9 Server supports industry standard Intel Xeon E5-2600 v3 and E5-2600 v4 processors with up to 22 cores, 12G SAS and 3.0 TB of HPE DDR4 SmartMemory.High efficiency redundant HPE Flexible Slot Power Supplies provide up to 96% efficiency (Titanium), HPE Flexible Slot Battery Backup module and support for the HPE Power Discovery Services offering.Improved ambient temperature standards with HPE Extended Ambient Operating Support (ASHRAE A3 and A4) and optional performance heatsinks help to reduce cooling costs.Enhanced performance with active and passive, single and double-wide GPU support for workload acceleration. -
Agile Infrastructure Management for Accelerating IT Service Delivery
With HPE ProLiant DL380 Gen9 Server, HPE OneView provides infrastructure management for automation simplicity across servers, storage and networking.Online personalized dashboard for converged infrastructure health monitoring and support management with HPE Insight Online.Configure in Unified Extensible Firmware Interface (UEFI) boot mode, provision local and remote with HPE iLO with Intelligent Provisioning and Scripting Toolkits.Embedded management to deploy, monitor and support your server remotely, out of band with HPE iLO.Optimize firmware and driver updates and reduce downtime with Smart Update, consisting of SUM (Smart Update Manager) and SPP (Service Pack for ProLiant). -
Industry Leading Serviceability
The HPE ProLiant DL380 Gen9 Server comes with a complete set of HPE Technology Services, delivering confidence, reducing risk and helping customers realize agility and stability. HPE provides consulting to transform your infrastructure; services to deploy, migrate and support your ProLiant Servers.Hewlett Packard Enterprise provides consulting advice to transform and modernize your infrastructure; services to deploy, migrate and support your new ProLiant servers and education to help you succeed quickly.
- HPE ProLiant DL380 Gen9 - rack-mountable - Xeon E5-2620V4 2.1 GHz - 16 GB - no HDD
- Server - rack-mountable
- Height (Rack Units)
- 2U
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon E5-2620V4 / 2.1 GHz (, up to 3 GHz, (8-core)
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2
- Cache Memory
- 20 MB L3 Cache
- Cache Per Processor
- 20 MB
- RAM
- 16 GB (installed) / 768 GB (max) - DDR4 SDRAM - Advanced ECC - PC4-19200
- Storage Controller
- RAID (SATA 6Gb/s / SAS 12Gb/s) - PCIe 3.0 x8 (Smart Array P440ar with 2GB FBWC)
- Server Storage Bays
- Hot-swap 2.5"
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- Matrox G200eH2
- Video Memory
- 16 MB
- Networking
- GigE
- Power
- AC 120/230 V
- Power Redundancy
- Optional
- 44.55 cm x 67.94 cm x 8.73 cm
- 14.759 kg
- Manufacturer Selling Program
- HP Top Value
- Limited warranty - parts and labour - 3 years - on-site
- Server
- Product Form Factor
- Rack-mountable - 2U
- 2-way
- Front Accessible Bays Qty
- 1
- Hot-Swap Bays Qty
- 8
Processor / Chipset
- CPU
- Intel Xeon E5-2620V4
- Clock Speed
- 2.1 GHz
- Max Turbo Speed
- 3 GHz
- Number of Cores
- 8-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
Cache Memory
- Installed Size
- L3 Cache - 20 MB
- 20 MB
RAM
- Installed Size
- 16 GB / 768 GB (max)
- Technology
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2400 MHz
- Memory Specification Compliance
- PC4-19200
- Form Factor
- DIMM 288-pin
- Slots
- 24 (Total)
- Registered, Online Spare Memory, quad channel memory architecture, HP SmartMemory
- RAM Supported
- PC4-17000 - 768 GB registered , PC4-17000 - 1.5 TB Load-Reduced
Hard Drive
- No HDD
Storage Controller
- 1 x RAID - PCIe 3.0 x8
- Controller Interface Type
- SATA 6Gb/s / SAS 12Gb/s
- Storage Controller Name
- Smart Array P440ar with 2GB FBWC
- Channel Qty
- 8
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60, RAID 1 ADM, RAID 10 ADM
- Buffer Size
- 2 GB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Matrox G200eH2
- Video Memory
- 16 MB
- Video Interfaces
- VGA
- Interface (Bus) Type
- PCI Express x2
- Ethernet Ports
- 4 x Gigabit Ethernet
- Ethernet Controller
- HP 331i
- Data Link Protocol
- Remote Management Controller
- Integrated Lights-Out 4
- Wake on LAN (WoL), PXE support
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
- Bays
- 8 (total) / 8 (free) x hot-swap 2.5" SFF , 1 (total) / 0 (free) x external 5.25"
- Slots
- 2 (total) / 1 (free) x CPU , 24 DIMM 288-pin , 2 (total) / 2 (free) x PCIe 3.0 x16 - half-length, full-height (x8 mode) , 1 (total) / 1 (free) x PCIe 3.0 x8 - half-length, full-height , 1 (total) / 1 (free) x microSD Card (internal)
- 4 x LAN (Gigabit Ethernet) - RJ-45 , 1 x HPE iLO - RJ-45 , 1 x VGA , 5 x USB 3.0 (1 front, 2 rear, 2 internal)
- Included Accessories
- Rack rail kit, cable management arm
- ACPI 2.0b, FCC Class A certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, WEEE, GB 9254, CNS 13438
- HP Top Value
- Power supply - hot-plug
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Installed Qty
- 1
- Max Supported Qty
- 2
- Voltage Required
- AC 120/230 V
- Power Provided
- 500 Watt
- 80 PLUS Certification
- 80 PLUS Platinum
- Efficiency
- 94%
Operating System / Software
- OS Certified
- SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, Oracle Solaris, Citrix XenServer, Canonical Ubuntu
- 44.55 cm
- 67.94 cm
- 8.73 cm
- 14.759 kg
- 10 °C
- 35 °C
- 8 - 90% (non-condensing)
