HPE DL380 Gen9 E5-2620v4 1P 16G Svr/TV
Quicklinx: CJD2WS00 Mfr#: 843556-425
  • Xeon
  • Red Hat Enterprise Linux
What is your server bottleneck...storage, processing, expansion? The world's best-selling server just got better. The HPE ProLiant DL380 Gen9 Server delivers the latest performance and expandability. Reliability, serviceability and near continuous availability, backed by a comprehensive warranty, makes it ideal for any server environment. Deploy the data center standard. Designed to reduce costs and complexity, leveraging Intel's latest E5-2600 v4 processors with 21% performance gain, plus the latest HPE 2400 MHZ DDR4 SmartMemory supporting 3.0 TB and up to 23% performance increase. Supporting 12 Gb/s SAS, 40 Gb NIC with broad range compute options. HPE Persistent Memory, the world's first NVDIMM optimized on ProLiant, offering unprecedented levels of performance for databases and analytic workloads. Run everything from the most basic to mission critical applications, and can be deployed with confidence.
  • Flexible Design Makes Your Investment "Future Proof" so it Can Grow as Your Business Needs Expand
    The HPE ProLiant DL380 Gen9 Server has a flexible redesigned chassis, including new HPE Universal Media Bay configuration options with 8 to 24 SFF and 4 or 12 LFF drive options along with NVMe options and additional rear drive support for expandability and investment protection.HPE Persistent Memory, the first Non-volatile DIMM (NVDIMM) optimized on HPE ProLiant, offering unprecedented levels of performance and data resiliency for databases and analytic workloads.In conjunction with the embedded SATA HPE Dynamic Smart Array B140i Controller for boot, data and media needs, the redesigned HPE Flexible Smart Array and HPE Smart SAS HBA Controllers allow you the flexibility to choose the optimal 12 Gb/s controller most suited to your environment.You have a choice of embedded 4x1GbE, HPE FlexibleLOM or PCIe standup 1GbE to 40GbE Adapters provide you flexibility of networking bandwidth and fabric so you can adapt and grow to changing business needs.
  • World-class Performance and Industry-leading Energy Efficiency
    The HPE ProLiant DL380 Gen9 Server supports industry standard Intel Xeon E5-2600 v3 and E5-2600 v4 processors with up to 22 cores, 12G SAS and 3.0 TB of HPE DDR4 SmartMemory.High efficiency redundant HPE Flexible Slot Power Supplies provide up to 96% efficiency (Titanium), HPE Flexible Slot Battery Backup module and support for the HPE Power Discovery Services offering.Improved ambient temperature standards with HPE Extended Ambient Operating Support (ASHRAE A3 and A4) and optional performance heatsinks help to reduce cooling costs.Enhanced performance with active and passive, single and double-wide GPU support for workload acceleration.
  • Agile Infrastructure Management for Accelerating IT Service Delivery
    With HPE ProLiant DL380 Gen9 Server, HPE OneView provides infrastructure management for automation simplicity across servers, storage and networking.Online personalized dashboard for converged infrastructure health monitoring and support management with HPE Insight Online.Configure in Unified Extensible Firmware Interface (UEFI) boot mode, provision local and remote with HPE iLO with Intelligent Provisioning and Scripting Toolkits.Embedded management to deploy, monitor and support your server remotely, out of band with HPE iLO.Optimize firmware and driver updates and reduce downtime with Smart Update, consisting of SUM (Smart Update Manager) and SPP (Service Pack for ProLiant).
  • Industry Leading Serviceability
    The HPE ProLiant DL380 Gen9 Server comes with a complete set of HPE Technology Services, delivering confidence, reducing risk and helping customers realize agility and stability. HPE provides consulting to transform your infrastructure; services to deploy, migrate and support your ProLiant Servers.Hewlett Packard Enterprise provides consulting advice to transform and modernize your infrastructure; services to deploy, migrate and support your new ProLiant servers and education to help you succeed quickly.
HPE ProLiant DL380 Gen9 - rack-mountable - Xeon E5-2620V4 2.1 GHz - 16 GB
Server - rack-mountable
Height (Rack Units)
2U
Server Scalability
2-way
1 x Intel Xeon E5-2620V4 / 2.1 GHz (3 GHz) (8-core)
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory
20 MB L3 Cache
Cache Per Processor
20 MB
RAM
16 GB (installed) / 768 GB (max) - DDR4 SDRAM - Advanced ECC - PC4-19200
Storage Controller
RAID (SATA 6Gb/s / SAS 12Gb/s) - PCIe 3.0 x8 (Smart Array P440ar with 2GB FBWC)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
No optical drive
Graphics Controller
Matrox G200eH2
Video Memory
16 MB
GigE
AC 120/230 V
Power Redundancy
Optional
44.55 cm x 67.94 cm x 8.73 cm
14.759 kg
Manufacturer Selling Program
HP Top Value
Limited warranty - parts and labour - 3 years - on-site
Server
Product Form Factor
Rack-mountable - 2U
Server Scalability
2-way
Front Accessible Bays Qty
1
Hot-Swap Bays Qty
8
Processor / Chipset
CPU
Max Turbo Speed
3 GHz
Number of Cores
8-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
Cache Memory
Installed Size_old
L3 Cache - 20 MB
Cache Per Processor
20 MB
RAM
Installed Size
16 GB / 768 GB (max)
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
Memory Specification Compliance
PC4-19200
DIMM 288-pin
Slots
24 (Total)
Registered, Online Spare Memory, quad channel memory architecture, HP SmartMemory
RAM Supported
PC4-17000 - 768 GB registered , PC4-17000 - 1.5 TB Load-Reduced
Hard Drive
No HDD
Storage Controller
1 x RAID - PCIe 3.0 x8
Controller Interface Type
Storage Controller Name
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60, RAID 1 ADM, RAID 10 ADM
Buffer Size
2 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Matrox G200eH2
Video Memory
16 MB
Video Interfaces
VGA
Interface (Bus) Type
PCI Express x2
Ethernet Ports
4 x Gigabit Ethernet
Ethernet Controller
HP 331i
Remote Management Controller
Integrated Lights-Out 4
Wake on LAN (WoL), PXE support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
Bays
8 (total) / 8 (free) x hot-swap 2.5" SFF , 1 (total) / 0 (free) x external 5.25"
Slots
2 (total) / 1 (free) x CPU , 24 DIMM 288-pin , 2 (total) / 2 (free) x PCIe 3.0 x16 - half-length, full-height (x8 mode) , 1 (total) / 1 (free) x PCIe 3.0 x8 - half-length, full-height , 1 (total) / 1 (free) x microSD Card (internal)
4 x LAN (Gigabit Ethernet) - RJ-45 , 1 x HP iLO - RJ-45 , 1 x VGA , 5 x USB 3.0 (1 front, 2 rear, 2 internal)
Rack rail kit, cable management arm
ACPI 2.0b, FCC Class A certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, WEEE, GB 9254, CNS 13438
HP Top Value
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Nominal Voltage
AC 120/230 V
Power Provided
500 Watt
80 PLUS Certification
80 PLUS Platinum
Efficiency
94%
Operating System / Software
OS Certified
SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, Oracle Solaris, Citrix XenServer, Canonical Ubuntu
44.55 cm
67.94 cm
8.73 cm
14.759 kg
10 °C
35 °C
8 - 90% (non-condensing)
