HPE DL360e Gen8 Intel Xeon E5-2420 (1.9GHz/6-core/15MB) CPU Kit
Quicklinx: 8KXRWS00 Mfr#: 660660-B21
  • Xeon
Intel Xeon E5-2420 - 1.9 GHz - 6-core - 12 threads - 15 MB cache - LGA1356 Socket - for ProLiant DL360e Gen8
Full Processor Option KitIntel® Xeon® Processor E5-2400 Product FamilyCompleting the Intel® Xeon® processor E5 family is the entry dual socket server processor, the Intel® Xeon® processor E5-2400 product family, which supports core features of the Intel Xeon processor E5 family such as Intel® Integrated I/O, Intel® Turbo Boost Technology 2.0, and Intel® Trusted Execution Technology. These processors offer growing small and medium businesses an easy path to the higher performance and reliability of an Intel Xeon processor E5 family-based platform. The Intel Xeon processor E5-2400 product family delivers up to 3x better performance then the Intel® Xeon® processor E3-1200v2 product family and enables higher system densities and lower total cost of ownership compared to a single socket server solution.
  • Enhanced performance
    Equipped with an Intel Xeon processor, this product delivers reliable and efficient performance for demanding applications and workloads.
  • Seamless integration
    Designed for compatibility, this processor seamlessly integrates into Hewlett Packard Enterprise systems, ensuring smooth operation and system stability.
Intel Xeon E5-2420 / 1.9 GHz processor
Processor Type
Intel Xeon E5-2420
Number of Cores
6-core / 12 threads
Cache
15 MB
Compatible Processor Socket
LGA1356 Socket
Clock Speed
1.9 GHz
Max Turbo Speed
2.4 GHz
Manufacturing Process
32 nm
Enhanced SpeedStep technology, Intel Virtualization Technology, Intel Turbo Boost Technology 2.0
Type / Form Factor
Intel Xeon E5-2420
Number of Cores
6-core
Number of Threads
12 threads
Cache
15 MB
Clock Speed
1.9 GHz
Max Turbo Speed
2.4 GHz
LGA1356 Socket
32 nm
Thermal Design Power
95 W
PCI Express Revision
3.0
PCI Express Lanes Qty
24
Architecture Features
Cache Memory
Installed Size
15 MB
