HPE DL360 DVD-RW OPTION
Quicklinx: 6MFDWS00 Mfr#: 532068-B21
  • DVD-RW
The DVD RW drive is capable of reading DVD 4.7 GB through 8.5 GB media. It can also read standard stamped, CD-R, and CD-RW media. This drive supports writing to CD-R, CD-RW, DVD +R/RW, and DVD -R/RW media via software utilities. For Microsoft operating systems, this is available by installing the included Roxio software disk. For other operating systems, an operating system-specific software utility is required for writing to media. The DVD-ROM drive is designed to read not only CD-ROM and CD -R/RW discs but also DVD-ROM, DVD-RAM, DVD +R/RW and DVD -R/RW discs.
  • Typical Customers are Those Who
    Want to perform local back up or retail/branch office configuration archiving.Want to locally install software/patches or load data.Require an OS boot disk that is larger than traditional floppy drives.Need the latest in optical drive support with DVD capacity.
HPE DVD-RW drive - Serial ATA - internal
DVD-RW drive - internal
Serial ATA
1.3 cm
Optical Storage
DVD-RW - 5.25" x 1/6H (Slim Line)
ProLiant DL360 G6, DL360 G6 Base, DL360 G6 Efficiency, DL360 G6 Entry, DL360 G7, DL360 G7 Base, DL360 G7 Central Management Server, DL360 G7 Efficiency, DL360 G7 Entry, DL360 G7 Performance, DL360 G7 Special Server
Serial ATA
1.3 cm
Optical Storage
HPE ProLiant DL360 G6, DL360 G6 Base, DL360 G6 Efficiency, DL360 G6 Entry, DL360 G7, DL360 G7 Base, DL360 G7 Central Management Server, DL360 G7 Efficiency, DL360 G7 Entry, DL360 G7 Performance, DL360 G7 Special Server
