Converts the DisplayPort connector on an HP Compaq Business Desktop computer or HP Workstation to a dual link DVI port. The adapter has a latching DisplayPort connector on one end, and a USB connector and DVI-D connector on the other end for connecting to a DVI monitor cable.
- HP DVI adapter
- DVI adapter
- Connectors
- DisplayPort - male , USB - male
- Connectors (Second End)
- DVI-D - female
- Designed For
- EliteDesk 705 G2, 705 G3, 800 G1, 800 G2, 800 G3, 800 G4; EliteOne 1000 G2, 800 G1, 800 G2, 800 G3; ENVY 27; ProDesk 400 G2.5, 400 G3, 400 G4, 400 G5, 40X G1, 490 G3, 600 G1, 600 G2, 600 G3, 600 G4; ProOne 400 G1, 400 G2, 400 G3, 440 G3, 600 G1, 600 G2, 600 G3; Workstation Z238, Z420, Z620, Z8 G4
- DVI adapter
- Connectors
- 20 pin DisplayPort - male , 4 pin USB Type A - male
- 24+1 pin digital DVI - female
- Designed For
- HP rp5800 Retail System , HP EliteDesk 700 G1, 705 G1, 705 G2, 705 G3, 800 G1, 800 G2, 800 G3, 800 G4 , HP EliteOne 1000 G2, 705 G1, 800 G1, 800 G1 Retail System, 800 G2, 800 G3 , HP ENVY 27-b101la, 27-b105nl, 27-b145se , HP ProDesk 400 G1, 400 G2, 400 G2.5, 400 G3, 400 G4, 400 G5, 405 G1, 405 G2, 490 G1, 490 G2, 490 G3, 600 G1, 600 G2, 600 G3, 600 G4 , HP ProOne 400 G1, 400 G2, 400 G3, 440 G3, 600 G1, 600 G2, 600 G3 , HP RP5 Retail System 5810 , HP Workstation xw4600, xw6600, xw8600, z200, z210, Z220, Z230, Z238, z400, Z420, z600, Z620, Z8 G4, z800, Z820 , HP Compaq 6000 Pro, 6200 Pro, 6300 Pro, 6300 Pro PC, 6305 Pro, 8200 Elite, 8200 Elite USDT PC, Elite 8000, Elite 8100, Elite 8300, Elite 8300 PC, Pro 4300, Pro 4300 PC
