HPE DDR4 16GB DIMM 288-pin 2400 MHz / PC4-19200
Quicklinx: DN6BWS00 Mfr#: 862976-B21
Small and medium business owners often must choose between the need for high-performance server memory that supports their workloads and the simultaneous desire to control capital and operating expenses. With HPE DDR4 Standard Memory, you don't need to choose between performance and cost efficiency. Unlike third-party alternatives, HPE Standard Memory is sourced from the highest-quality DRAMS and undergoes a rigorous testing and authentication process. This extensive testing ensures that it is completely compatible with and optimized for entry-level HPE server platforms to perform to industry-defined specifications.
  • High Performance
    HPE DDR4 Standard Memory matches the performance capabilities of the new generation of Intel processors.HPE DDR4 Standard Memory reduces downtime and lowers energy costs using advanced error detection.
  • High Reliability
    HPE DDR4 Standard Memory provides excellent quality and support for a selection of HPE Gen10 and Gen9 servers.HPE engineers quality and reliability into every HPE DDR4 Standard Memory product.
  • Increased Efficiency
    HPE offers an affordable solution for small and medium business and remote and branch office customers with DDR4 Standard Memory.
HPE - DDR4 - module - 16 GB - DIMM 288-pin - 2400 MHz / PC4-19200 - unbuffered
Memory module
16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL17 (17-17-17)
Dual rank, unbuffered
Voltage
1.2 V
HP 862976-B21, HP 869538-001
ProLiant DL20 Gen9, MicroServer Gen10, ML30 Gen9
16 GB
Upgrade Type
System specific
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL17 (17-17-17)
ECC
Chips Organization
1024 x 8
Voltage
1.2 V
HPE ProLiant DL20 Gen9, DL20 Gen9 Base, DL20 Gen9 Entry, DL20 Gen9 Performance, DL20 Gen9 Solution, DL20 Gen9 Special Server, MicroServer Gen10, MicroServer Gen10 Entry, MicroServer Gen10 Performance, MicroServer Gen10 Solution, MicroServer Gen10 Stockage Collaboration, ML30 Gen9, ML30 Gen9 Base, ML30 Gen9 Entry, ML30 Gen9 Performance, ML30 Gen9 Solution
