HPE D3700 Storage Enclosure
Quicklinx: CL9VWS00 Mfr#: QW967A
Has your business exceeded your storage capacity? Manage your small and midrange business' growing storage needs by deploying the HP D3000 Enclosures, the next generation 12 Gb SAS low-cost, high-capacity, tiered external storage system. The HP D3000 Enclosures are ideal for your small application environments, remote offices and departmental locations. The new 12 Gb SAS enclosures-Large Form Factor (LFF) D3600 with 12 drive bays and Small Form Factor (SFF) D3700 with 25 drive bays-offer flexible, modular solutions to simplify capacity expansion of HP ProLiant server and HP BladeSystem environments to external storage without having to make the full move to SAN or NAS. This allows you to buy what is needed today and purchase additional capacity as data storage needs grow. D3000 Enclosures support HP SmartDrive Carrier. Buy and maintain a common set of HP ProLiant drives for Gen8/9 ProLiant servers. Total support can grow up to 96 LFF or 200 SFF drives.
  • Affordable Storage for Capacity Demand
    HPE D3000 Enclosures 12 Gb SAS provides a higher level of redundancy and reliability, reducing single-points-of-failure within the storage network.The modular platform provides investment protection by allowing purchases based on your current need and future plans without hidden management fees.Increase your data speed with enterprise-class, dual-port SAS drives as need and budget dictate.The HPE D3610 and HPE D3710 standardizing on Gen10 branding/industrial design to align with HPE ProLiant Gen10/Gen10+ Servers.
  • Flexible and Scalable with Room to Expand
    The HPE D3000 Enclosures give you the flexibility to mix and match SAS, SATA and Solid State drives in the same enclosure, and extend the benefit of tiered storage to your customers.Designed to give you room to expand as your storage demands increase, the HPE D3610 LFF can grow to 96 drives by daisy-chaining up to eight HPE D3610 LFF enclosures from a single controller port.With the HPE D3710 SFF you can increase to 200 drives or up to eight HPE D3710 SFF enclosures from a single controller port.Smart Array Controllers allow mixing D3600 or the D3610 and the D3700 or the D3710 enclosures for expansion, up to four D3600 or D3610 and four D3700 or D3710 (4x LFF and 4x SFF) allowing for expansion up to 148 drives.Solid state drive support for up to 25 drives per Smart Array Controllers on all HPE D3000 models.
  • Easy to Manage
    The HPE D3000 Enclosures support the HPE SmartDrive Carrier, enabling a single set of common drives for Gen10 and Gen 10+ ProLiant servers and D3000 Enclosures.The HPE D3000 Enclosures uses familiar HPE ProLiant management tools including HPE Systems Insight Manager and the HPE Array Configuration Utility (ACU) software.The HPE D3000 Enclosures are compatible with selected HPE Smart Array SAS Controllers and HBAs.Little IT expertise is required to manage the enclosures.
  • Software-Defined Storage
    Microsoft Windows 2012 Storage Spaces support Gen9 ProLiant servers and H241 HBA.
HPE D3700 - storage enclosure
Storage enclosure
Enclosure Type
Rack-mountable - 2U
Max Supported Capacity
60 TB
0 (installed) / 25 (max)
Supported Drives
SATA-600 / SAS-3
Hard Drive
No HDD
AC 120/230 V - 50/60 Hz
Power Redundancy
44.8 cm x 54.6 cm x 8.7 cm
17.2 kg
3-year warranty
Storage enclosure
Enclosure Type
Rack-mountable - 2U
Chassis
0
Supported Devices / Modules Qty
25
Supported Drives
SATA-600 / SAS-3
Storage
60 TB
CPU
No CPU
Hard Drive
No HDD
Expansion Bays
25 (total) / 25 (free) x hot-swap - 2.5" SFF
2 x SAS 12Gb/s
Redundant fans, firmware upgradable, 92% efficiency power supply
2 x mini SAS HD cable - 50 cm
Rack mounting kit
2 x internal power supply - hot-plug
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
Power Provided
460 Watt
80 PLUS Certification
80 PLUS Gold
44.8 cm
54.6 cm
8.7 cm
17.2 kg
Limited warranty - parts - 3 years
10 °C
10 - 90%
Sound Emission
53 dBA
CL9V HPE 2.0m External Mini SAS High Density to Mini SAS Cable In Stock £74.76
