The HP BladeSystem c-Class SFP Transceivers provide high performance Ethernet connectivity and bring customers more choices for using either copper or optical cables.
- HPE - SFP (mini-GBIC) transceiver module - 10Mb LAN, 100Mb LAN, GigE
- Form Factor
- Plug-in module
- Cabling Type
- 10Base-T, 100Base-TX, 1000Base-T
- Data Transfer Rate
- 1 Gbps
- Data Link Protocol
- Designed For
- HP 10Gb Ethernet Pass-Thru Module for c-Class BladeSystem; HPE 1/10Gb-F Virtual Connect Ethernet Module, 6120G/XG Blade Switch, 6120XG Blade Switch; BLc3000 Enclosure; BLc7000 Single-Phase Enclosure; BLc7000 Three-Phase Enclosure; Virtual Connect Flex-10
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 1 Gbps
- 1 x Ethernet 1000Base-T
- Compatible Slots
- 1 x SFP (mini-GBIC)
- Designed For
- HP 10Gb Ethernet Pass-Thru Module for c-Class BladeSystem , HPE 1/10Gb-F Virtual Connect Ethernet Module, 6120G/XG Blade Switch, 6120XG Blade Switch , HPE BLc3000 Enclosure , HPE BLc7000 Single-Phase Enclosure w/2 Power Supplies and 4 Fans w/8 Insight Control Environment Trial Licenses, w/6 Power Supplies and 10 Fans w/16 Insight Control Environment Licenses , HPE BLc7000 Three-Phase Enclosure w/6 Power Supplies and 10 Fans w/16 Insight Control Environment Licenses , HPE Virtual Connect Flex-10
