HPE 96W Smart Storage Battery
Quicklinx: F34SWS00 Mfr#: 878643-001
£55.51 ex VAT
£66.61 inc VAT
The HPE Smart storage battery is a lithium-ion, low-halogen centralized backup source and is required to backup the write cache content onto flash memory on the HPE Smart Array Gen10 and Gen9 performance RAID (P-class) controllers in case of an unplanned server power loss. The battery is also the backup power source for HPE NVDIMMS and allows any data in flight on the DRAM to be moved to the non-volatile NAND flash. Only one battery is required per server as it can support multiple devices.
  • Enhanced efficiency
    The 96 W Smart Storage battery significantly boosts the efficiency of your storage solutions, ensuring reliable power backup and smooth operation.
  • Reliable performance
    Designed by Hewlett Packard Enterprise, this storage battery is built for consistent, reliable performance, making it an essential component for your data management needs.
HPE 96W Smart Storage - battery back up
Battery back up
Nimble Storage dHCI Large Solution with HPE ProLiant DL380 Gen10; ProLiant DL360 Gen9, DL380 Gen10, DL385 Gen10, DL388 Gen10, DL580 Gen10
Battery back up
Flash Backed Write Cache (FBWC)
HPE Nimble Storage dHCI Large Solution with HPE ProLiant DL380 Gen10 , HPE ProLiant DL360 Gen9, DL360 Gen9 Base, DL360 Gen9 CMS, DL360 Gen9 Entry, DL360 Gen9 Performance, DL360 Gen9 Special Server, DL380 Gen10, DL380 Gen10 All Flash Server for Datera, DL380 Gen10 Base, DL380 Gen10 Entry, DL380 Gen10 Entry SMB, DL380 Gen10 for Cohesity DataPlatform, DL380 Gen10 for SAP HANA Compute Block, DL380 Gen10 High Performance, DL380 Gen10 Hybrid Server for Datera, DL380 Gen10 Network Choice, DL380 Gen10 Network Choice for CTERA, DL380 Gen10 NVMe All Flash Server for Datera, DL380 Gen10 Performance, DL380 Gen10 Server for CTERA, DL380 Gen10 SMB, DL380 Gen10 SMB Networking Choice, DL380 Gen10 Solution, DL385 Gen10, DL385 Gen10 Base, DL385 Gen10 Entry, DL385 Gen10 High-Performance, DL385 Gen10 Performance, DL385 Gen10 SMB, DL385 Gen10 Solution, DL388 Gen10, DL388 Gen10 Network Choice, DL580 Gen10, DL580 Gen10 Base, DL580 Gen10 Entry, DL580 Gen10 Performance
Brand: HPE
