Looking for high-efficiency power solutions at an entry-level price for your ProLiant Gen9 Essential Server? HPE Entry-Level Power Supplies offer an optimized set of features with options for both redundant and non-redundant power configurations. The HPE 550W FIO Power Supply offers Silver-certified 80 Plus power efficiency up to 89% with an optimized set of features for non-redundant power configurations. The HPE 900W Gold Redundant AC Power Input Module with Power Backplane can be configured to support power redundancy in ProLiant servers that offer only a single power supply bay, providing additional protection against power loss. With an 80 Plus Gold power efficiency rating up to 92%, this power option helps to reduce operating expenses while protecting against trapped power capacity in the data center. Hot-plug AC power input modules allow for better serviceability with fast and easy deployment and replacement.
Optimized, High Efficiency Power Supply
The HPE 550W FIO Power Supply is a non-redundant, Silver-certified 80 Plus power option (up to 89% efficiency) offering an optimized set of features at an entry-level price.Compatible across a wide range of HP ProLiant Gen9 Essential Servers providing a common power supply spares strategy that helps to reduce data center costs. -
Innovative, High Efficiency Entry-Level Power Supply with Support for Power Redundancy
The HPE 900W Gold Power Supply can be configured to support power redundancy in ProLiant servers that offer only a single power supply bay, providing additional protection against power loss.Gold certified 80 Plus power efficiency rating, up to 92% efficiency, reduces operating expenses and trapped power in the data center.Hot-plug AC power input modules allow for better serviceability with fast and easy deployment and replacement.Compatible across a wide range of HP ProLiant Gen9 Essential Servers providing a common power supply spares strategy that helps to reduce data center costs.
- HPE - power supply - redundant - 900 Watt
- Power supply - redundant - plug-in module
- 80 PLUS Certification
- 80 PLUS Gold
- Input Voltage
- AC 110-240 V
- Power Capacity
- 900 Watt
- Designed For
- ProLiant DL180 Gen9 (900 Watt), DL180 Gen9 Base (900 Watt), DL180 Gen9 Entry (900 Watt), DL180 Gen9 Storage (900 Watt), DL20 Gen9 (900 Watt), DL20 Gen9 Entry (900 Watt), DL20 Gen9 Performance (900 Watt), DL80 Gen9 Entry (900 Watt)
- Input Voltage
- AC 110-240 V
- Power Capacity
- 900 Watt
- Efficiency
- 92%
- 80 PLUS Gold
- Designed For
- HPE ProLiant DL180 Gen9 (900 Watt), DL180 Gen9 Base (900 Watt), DL180 Gen9 Entry (900 Watt), DL180 Gen9 Storage (900 Watt), DL20 Gen9 (900 Watt), DL20 Gen9 Entry (900 Watt), DL20 Gen9 Performance (900 Watt), DL80 Gen9 Entry (900 Watt)
