HPE 8GB PC3-10600R DDR3-1333 MHX RDIMM Registered ECC Memory Module
IT professionals rely on HPE quality to ensure maximum productivity. As the power of applications processors memory adapters and storage devices increases high-end computer users are seeking ways to optimize their system performance
Internal memory: 8 GB
Internal memory type: DDR3
Memory clock speed: 1333 MHz
Memory form factor: 240-pin DIMM
Signal processing: Registered
- HPE - DDR3 - module - 8 GB - DIMM 240-pin - 1333 MHz / PC3-10600 - registered
- Product Type
- Memory module
- Capacity
- 8 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 1333 MHz (PC3-10600)
- Registered
- Capacity
- 8 GB
- Upgrade Type
- System specific
- DRAM memory module
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- ECC
- Registered
- Compatible Slots
- 1 x memory - DIMM 240-pin
- RoHS
