HPE 8GB DDR4 DIMM 288-pin 2133 MHz/PC4-17000 CL15 1.2V Registered ECC
Quicklinx: BK9GWS00 Mfr#: 759934-B21
Maximize your PC performance with HP Memory. Upgrading your memory is a cost-effective way to boost your system performance without having to upgrade your processor.
  • High Performance
    HPE DDR4 2400 MT/s server memory provides up to a 23% increase in throughput at DDR4-2400 MT/s in comparison to DDR4 2133 MT/s memory modules.HPE DDR4 2400 MT/s server memory provides a 14 to 33% improvement in memory performance depending on platform and configuration in comparison to DDR4 2133 MT/s memory modules.HPE DDR4 2400 MT/s server memory provides up to a 25% improvement in latency at DDR4-2400 MT/ s in comparison to DDR4 2133 MT/s memory modules.HPE DDR4 2400 MT/s server memory provides a 100% increase in maximum memory capacity with the introduction of the 128GB LRDIMM.
  • High Reliability
    HPE DDR4 SmartMemory modules have been tested and qualified on all HPE server platforms to ensure the highest level of signal integrity.HPE DDR4 SmartMemory prevents unnecessary DIMM replacement and reduces server downtime with advanced memory error detection technology.HPE server memory is made of the highest quality materials, reducing issues that may affect signal integrity, increasing system reliability.
  • Reducing Power Consumption
    HPE DDR4 2400 MT/s SmartMemory modules reduce power consumption by up to 20% in comparison to DDR4 2133 MT/s memory modules.HPE server memory speed targets provide customers with memory that performs above industry standards, allowing them to increase performance without having to increase the amount of memory purchased.
HPE - DDR4 - module - 8 GB - DIMM 288-pin - 2133 MHz / PC4-17000 - registered
Memory module
8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15 (15-15-15)
Dual rank, registered
Voltage
1.2 V
HP 759934-B21
Apollo 4200 Gen9; ProLiant BL460c Gen9, BL660c Gen9, DL120 Gen9, DL160 Gen9, DL180 Gen9, DL360 Gen9, DL380 Gen9, DL388 Gen9, DL560 Gen9, DL60 Gen9, DL80 Gen9, ML110 Gen9, ML150 Gen9, ML350 Gen9, WS460c Gen9, XL170r Gen9, XL190r Gen9, XL230a Gen9, XL250a Gen9
8 GB
Upgrade Type
System specific
HP 759934-B21
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL15 (15-15-15)
ECC
Chips Organization
X8
Voltage
1.2 V
HPE Apollo 4200 Gen9 for Google , HPE ProLiant BL460c Gen9, BL460c Gen9 Base, BL460c Gen9 Entry, BL460c Gen9 Performance, BL660c Gen9, DL120 Gen9, DL160 Gen9, DL160 Gen9 Base, DL160 Gen9 Entry, DL180 Gen9, DL180 Gen9 Base, DL180 Gen9 Entry, DL180 Gen9 Storage, DL360 Gen9, DL360 Gen9 Base, DL360 Gen9 CMS, DL360 Gen9 Entry, DL360 Gen9 High Performance, DL360 Gen9 Performance, DL380 Gen9, DL380 Gen9 Base, DL380 Gen9 Entry, DL380 Gen9 Performance, DL388 Gen9, DL388 Gen9 Base, DL560 Gen9, DL560 Gen9 Base, DL560 Gen9 Entry, DL560 Gen9 Performance, DL60 Gen9, DL80 Gen9, DL80 Gen9 Entry, ML110 Gen9, ML110 Gen9 Base, ML110 Gen9 Entry, ML150 Gen9, ML150 Gen9 Base, ML150 Gen9 Entry, ML150 Gen9 Performance, ML350 Gen9, ML350 Gen9 Base, ML350 Gen9 Entry, ML350 Gen9 Performance, WS460c Gen9 Graphics, WS460c Gen9 Graphics Expansion, XL170r Gen9, XL190r Gen9, XL230a Gen9, XL230a Gen9 Compute Tray, XL230a Gen9 Compute Tray (12G), XL230a Gen9 Compute Tray (6G), XL230a Gen9 NHP Compute Tray (12G), XL250a Gen9 Accelerator Tray
