HPE 8GB 1RX4 PC4-2133P-R DDR4 DIMM 288-Pin Kit
Quicklinx: 9ZXTWS00 Mfr#: 726718-B21
Maximize your PC performance with HP Memory. Upgrading your memory is a cost-effective way to boost your system performance without having to upgrade your processor.
  • High Performance
    HPE DDR4 Smart Memory 3200 MT/s provides improvements in bandwidth in comparison to DDR4 2933 MT/s memory modules.HPE DDR4 Smart Memory delivers improvements in latency at 3200 MT/s in comparison to DDR4 2933 MT/s memory modules.
  • High Reliability
    Hewlett Packard Enterprise tests and qualifies HPE DDR4 Smart Memory modules on all HPE server platforms to deliver the highest level of signal integrity.HPE DDR4 Smart Memory prevents unnecessary DIMM replacement and reduces server downtime with advanced memory error detection technology.HPE uses the highest quality materials for its DDR4 server memory, reducing issues that may affect signal integrity and increasing system reliability.HPE provides server memory that performs above industry standards, enabling customers to increase the performance of their servers without having to increase the amount of memory purchased.
HPE - DDR4 - module - 8 GB - DIMM 288-pin - 2133 MHz / PC4-17000 - registered
Memory module
8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15 (15-15-15)
Single rank, registered
Voltage
1.2 V
HP 726718-B21
Apollo 4200 Gen9, 4520 Gen9, 4530; ProLiant BL460c Gen9, BL660c Gen9, DL160 Gen9, DL180 Gen9, DL360 Gen9, DL380 Gen9, DL388 Gen9, DL560 Gen9, DL580 Gen9, DL80 Gen9, ML110 Gen9, ML350 Gen9, WS460c Gen9, XL170r Gen9, XL190r Gen9, XL230a Gen9, XL250a Gen9; StoreEasy 1450, 1850, 3850
8 GB
Upgrade Type
System specific
HP 726718-B21
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL15 (15-15-15)
ECC
Chips Organization
X4
Voltage
1.2 V
HPE Apollo 4200 Gen9 for Google, 4520 Gen9, 4530 , HPE ProLiant BL460c Gen9, BL460c Gen9 Base, BL460c Gen9 Entry, BL460c Gen9 Performance, BL660c Gen9, DL160 Gen9, DL160 Gen9 Base, DL160 Gen9 Entry, DL180 Gen9, DL180 Gen9 Base, DL180 Gen9 Entry, DL180 Gen9 Storage, DL360 Gen9, DL360 Gen9 Base, DL360 Gen9 CMS, DL360 Gen9 Entry, DL360 Gen9 High Performance, DL360 Gen9 Performance, DL380 Gen9, DL380 Gen9 Base, DL380 Gen9 Entry, DL380 Gen9 Performance, DL388 Gen9, DL388 Gen9 Base, DL560 Gen9, DL560 Gen9 Base, DL560 Gen9 Entry, DL560 Gen9 Performance, DL580 Gen9, DL580 Gen9 Database, DL580 Gen9 SAP HANA Scale-out Base Configuration, DL580 Gen9 SAP HANA Scale-up Base Configuration, DL80 Gen9, DL80 Gen9 Entry, ML110 Gen9, ML110 Gen9 Base, ML110 Gen9 Entry, ML350 Gen9, ML350 Gen9 Base, ML350 Gen9 Entry, ML350 Gen9 Performance, WS460c Gen9 Graphics, WS460c Gen9 Graphics Expansion, XL170r Gen9, XL190r Gen9, XL230a Gen9, XL230a Gen9 Compute Tray, XL230a Gen9 Compute Tray (12G), XL230a Gen9 Compute Tray (6G), XL230a Gen9 NHP Compute Tray (12G), XL250a Gen9 Accelerator Tray , HPE StoreEasy 1450, 1850, 3850 Gateway Single Node
