HPE 800W FS Platinum Hot Plug Power Supply Kit
Quicklinx: DTRBWS00 Mfr#: 720479-B21
Power Rating: 800watt, 800watt
£375.33 ex VAT
£450.39 inc VAT
How do you improve data center power efficiency without impacting IT performance? HP Flexible Slot Power Supplies provide up to 96% power efficiency with 80Plus Titanium-certified power supplies that lower server power requirements and reduce power waste in your data center. Flex Slot Power Supplies have a form factor that is 25% smaller than previous generation power supplies, providing more space to add additional server options and improve the performance of your servers. Flex Slot Power Supplies provide fast, tool-less hot plug access to server power supplies for greater serviceability and are supported across the entire ProLiant DL300 Gen9 Server family, simplifying your spares strategy and further reducing data center costs. Are you currently using or interested in the HP Power Discovery Services solution? Support for Power Discovery Services can be added to all ProLiant DL300 Gen9 Servers with the Flex Slot 800W Titanium or Flex Slot 1400W Platinum Plus Power Supply option.
  • Improve Data Center Efficiency Without Impacting IT Performance
    HPE Flexible Slot Power Supplies provide up to 96% power efficiency with 80 Plus Titanium-certified options that lower server power requirements and reduce power waste in your data center.96% efficient power supplies comply with the European Union (EU) Commission regulation 2019/424 (EU Lot 9) efficiency requirements.The power supply form factor is 25% smaller than previous generation HPE Common Slot Power Supplies, leaving more space to add server options improving the performance of your servers.Fast, tool-less hot-plug access simplifies and enhances serviceability.Support HPE ProLiant Gen10, Gen10 Plus and Gen11 servers, select HPE Apollo Gen10 & Gen10 Plus systems, and HPE Alletra 4100 data storage servers, simplifying your spares strategy and further reducing data center costs.
HPE - power supply - hot-plug / redundant - 800 watt - 915 VA
Power supply - hot-plug / redundant - plug-in module
Specification Compliance
Flex Slot
80 PLUS Certification
80 PLUS Platinum
910 g
Input Voltage
AC 100-240 V
Power Capacity
800 watt / 915 VA
6.8 cm x 22.53 cm x 4.04 cm
Apollo 4200 Gen9, 4510 Gen9, 4520 Gen9, 4530; ProLiant DL360 Gen9, DL380 Gen9, ML350 Gen9; SimpliVity 380 Gen9
Flex Slot
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Power Capacity
800 watt / 915 VA
Efficiency
94%
80 PLUS Platinum
UL, TUV, C-Tick, BSMI, cUL, CCC, KCC, WEEE, CISPR
5 °C
55 °C
5 - 95% (non-condensing)
6.8 cm
22.53 cm
4.04 cm
910 g
Shipping Width
37.47 cm
Shipping Depth
14.61 cm
Shipping Height
19.05 cm
Shipping Weight
1.59 kg
HPE Apollo 4200 Gen9 for Google (800 watt), 4510 Gen9 (800 watt), 4520 Gen9 (800 watt), 4530 (800 watt) , HPE ProLiant DL360 Gen9 (800 watt), DL360 Gen9 Base (800 watt), DL360 Gen9 CMS (800 watt), DL360 Gen9 Entry (800 watt), DL360 Gen9 High Performance (800 watt), DL360 Gen9 Performance (800 watt), DL380 Gen9 (800 watt), DL380 Gen9 Base (800 watt), DL380 Gen9 Entry (800 watt), DL380 Gen9 Performance (800 watt), ML350 Gen9 (800 watt), ML350 Gen9 Base (800 watt), ML350 Gen9 Entry (800 watt), ML350 Gen9 Performance (800 watt) , HPE SimpliVity 380 Gen9 Node (800 watt)
Brand: HPE
