HPE 800W FS Plat HT PLG LH Power Supply
Quicklinx: DR9LWS00 Mfr#: 865414-B21
How do you improve data center power efficiency without impacting IT performance? HPE Flexible Slot Power Supplies provide up to 96% power efficiency with 80PLUS Titanium-certified power supplies that lower server power requirements and reduce power waste in your data center1. Its form factor is 25% smaller than previous generation power supplies, providing more space to add additional server options and improve the performance of your servers. These power supplies provide fast, tool-less hot plug access to server power supplies for greater serviceability, and are supported across the entire servers/gen10-servers.html">HPE ProLiant Gen10, HPE ProLiant 300 Gen9 server series families, HPE Apollo 2000 and HPE Apollo 4000 series, simplifying your spares strategy and further reducing data center costs.
  • Improve Data Center Efficiency Without Impacting IT Performance
    HPE Flexible Slot Power Supplies provide up to 96% power efficiency with 80 Plus Titanium-certified options that lower server power requirements and reduce power waste in your data center.96% efficient power supplies comply with the European Union (EU) Commission regulation 2019/424 (EU Lot 9) efficiency requirements.The power supply form factor is 25% smaller than previous generation HPE Common Slot Power Supplies, leaving more space to add server options improving the performance of your servers.Fast, tool-less hot-plug access simplifies and enhances serviceability.Support HPE ProLiant Gen10, Gen10 Plus and Gen11 servers, select HPE Apollo Gen10 & Gen10 Plus systems, and HPE Alletra 4100 data storage servers, simplifying your spares strategy and further reducing data center costs.
HPE - power supply - hot-plug - 800 Watt - 908 VA
Power supply - hot-plug - plug-in module
Specification Compliance
Flex Slot
80 PLUS Certification
80 PLUS Platinum
1.81 kg
Input Voltage
AC 100-240 V
Power Capacity
800 Watt / 908 VA
Input Connectors
Power IEC 60320 C14
20.32 cm x 33.02 cm x 10.16 cm
Apollo 4200 Gen10; Nimble Storage dHCI Large Solution with HPE ProLiant DL380 Gen10, Medium Solution with HPE ProLiant DL325 Gen10, Medium Solution with HPE ProLiant DL360 Gen10, Small Solution with HPE ProLiant DL360 Gen10; ProLiant DL325 Gen10, DL360 Gen10, DL380 Gen10, DL560 Gen10, DX385 Gen10
Flex Slot
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Input Connectors
Power IEC 60320 C14
Power Capacity
800 Watt / 908 VA
Efficiency
94%
80 PLUS Platinum
UL, TUV, C-Tick, BSMI, cUL, CCC, KCC, WEEE, low halogen, CISPR Class A
5 °C
55 °C
5 - 95% (non-condensing)
20.32 cm
33.02 cm
10.16 cm
1.81 kg
HPE Apollo 4200 Gen10 192TB Qumulo Hybrid Node (800 Watt), 4200 Gen10 336TB Archive Node with 25Gb NIC for Qumulo (800 Watt), 4200 Gen10 384TB 25Gb Capacity Server for Cohesity DataPlatform (800 Watt), 4200 Gen10 384TB Capacity Server for Cohesity DataPlatform (800 Watt), 4200 Gen10 for HPE Ezmeral Container Platform (800 Watt), 4200 Gen10 for HPE Ezmeral Tracking (800 Watt), 4200 Gen10 Qumulo Archive Node (800 Watt) , HPE Nimble Storage dHCI Large Solution with HPE ProLiant DL380 Gen10 (800 Watt), Medium Solution with HPE ProLiant DL325 Gen10 Plus (800 Watt), Medium Solution with HPE ProLiant DL360 Gen10 (800 Watt), Small Solution with HPE ProLiant DL360 Gen10 (800 Watt) , HPE ProLiant DL180 Gen10 Entry (800 Watt), DL325 Gen10 Plus All-NVMe Flash Node for Qumulo (800 Watt), DL325 Gen10 Plus All-NVMe Flash Node for Software Defined Storage (800 Watt), DL325 Gen10 Plus for Weka BAse Tracking (800 Watt), DL325 Gen10 Plus for Weka Expansion Tracking (800 Watt), DL360 Gen10 All Flash Server for Weka (800 Watt), DL360 Gen10 Compute Server for Cohesity DataPlatform (800 Watt), DL360 Gen10 Performance for Cohesity DataPlatform (800 Watt), DL360 Gen10 Remote Office Branch Office Server for Cohesity DataPlatform (800 Watt), DL380 Gen10 48TB Server for Cohesity DataPlatform (800 Watt), DL380 Gen10 96TB Server for Cohesity DataPlatform (800 Watt), DL380 Gen10 All Flash Server for Datera (800 Watt), DL380 Gen10 for SAP HANA Compute Block (800 Watt), DL380 Gen10 Hybrid Server for Datera (800 Watt), DL380 Gen10 Network Choice for CTERA (800 Watt), DL380 Gen10 Server for CTERA (800 Watt), DL380 Gen10 SMB Networking Choice (800 Watt), DL385 Gen10 SMB (800 Watt), DL560 Gen10 for SAP HANA Compute Block (800 Watt), DX385 Gen10 Plus (800 Watt), DX385 Gen10 Plus Network Choice (800 Watt), ML350 Gen10 SMB (800 Watt) , HPE SimpliVity 380 Gen10 Network Choice G Node (800 Watt), 380 Gen10 Network Choice H Node (800 Watt)
