With simple 0U and 1U installation options, HPE Basic Power Distribution Units are available in multiple form factors allowing you to configure access to power in your rack where you need it the most. HPE Basic PDUs provide a low-profile single-piece design allowing easy access to rear devices for maintenance. Vertical PDUs can be installed on either side of the rack with outlets facing the back of the rack for easy access and improved clearance. For higher power density configurations, they can be installed side by side on both sides of the rack with the outlets facing towards the center. Horizontal/Modular PDUs offer a modular architecture designed for data center customers who want to maximize power distribution and space efficiencies. The Control Unit or core can be mounted in any 1U space or in 0U space on the side of HPE Racks between the RETMA rails. Extension Bars mount directly to the frame so you can configure access to power where you need it.
Powerfully Built Power Distribution, Because no two Environments are the Same
HPE Basic Power Distribution Units are backed by a 3-year warranty. Quality, guaranteed.Premium materials and robust construction guarantee power continuity and maintained performance at elevated temperatures.HPE Basic Power Distribution Units include vertical and horizontal models with power output options ranging from 1.9kVA to 22kVA.Single and three-phase models to meet all your facility power needs. -
Our Basic PDUs get Power where you Need it to Go – and Keep it There
HPE Basic Power Distribution Units Horizontal/Modular PDU Models can be installed in any U position in your rack.Integrated cord retention to connect the right cord to the right outlet, quickly and easily. -
Vertical PDU Models use Button and Keyhole Mounting for Simple Drop in Install
HPE Basic Power Distribution Units vertical form factor models have a wide range of single and three-phase options providing up to 22kVA of output power.Mounts vertically on either side in the rear of the rack using industry standard button and keyhole mounting. Standard mounting faces the outlet towards the rear of the rack preventing interference in the maintenance zone between rear RETMA rails.Using the optional configuration of facing the outlets into the rack, multiple PDUs can be mounted on one side of the rack for higher power density. -
Getting Power Where it Needs to go has Never Been Easier, from Purchase to Prime Time
HPE Basic Power Distribution Units have a wide range of mounting options to fit every application. Power where you need it, plus more room for compute.Highest-density PDUs on market means more power and less headache for even the most demanding compute applications.Tool-less installation, low profile and modular extensions simplify configuration and reduce time to deployment.HPE Foundation Care means your power isn't the only thing that's protected – the warranty from your HPE servers extends to your PDUs.
- HPE Basic Power Distribution Unit - power distribution unit - 7360 VA
- Power distribution unit
- Localisation
- Japan, North America
- Output Voltage
- 230 V
- Power Capacity
- 7360 VA
- Input Connectors
- Power IEC 60320 C13, power IEC 60320 C19
- Output connectors
- 24 x power IEC 60320 C13 , 6 x power IEC 60320 C19
- 48 cm x 9.5 cm x 140 cm
- Designed For
- Apollo 4510 Gen9; ProLiant c3000, ML310e Gen8 v2, ML310e Gen8 v2 Base, ML310e Gen8 v2 Enty, ML310e Gen8 v2 Performance, ML350e Gen8 v2, ML350e Gen8 v2 Base, SL210t Gen8 1U Node, SL250s Gen8 Left Tray, SL250s Gen8 Right Tray, SL270s Gen8 1U Left Half Width Tray, SL270s Gen8 1U Right Half Width Tray
- Localisation
- Input Voltage Range
- AC 200 - 240 V
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- 230 V
- Max Electric Current
- 32 A
- Power Capacity
- 7360 VA
- Cables Included
- Power cable - integrated - 2.4 m
- UL, cUL
- 48 cm
- 9.5 cm
- 140 cm
- Designed For
- HPE Apollo 4510 Gen9 , HPE ProLiant c3000, ML310e Gen8 v2, ML310e Gen8 v2 Base, ML310e Gen8 v2 Enty, ML310e Gen8 v2 Performance, ML350e Gen8 v2, ML350e Gen8 v2 Base, SL210t Gen8 1U Node, SL250s Gen8 Left Tray, SL250s Gen8 Right Tray, SL270s Gen8 1U Left Half Width Tray, SL270s Gen8 1U Right Half Width Tray
