HPE 600GB SAS 15K SFF SC DS HDD
Quicklinx: DXSHWS00 Mfr#: 870757-B21
14 In Stock
£223.08 ex VAT
£267.69 inc VAT
Do your servers need high-performance Enterprise hard drives for both your mission-critical and I/O intensive applications? HPE Server Enterprise Hard Drives offer the highest level of performance and reliability for your most demanding application workloads. They deliver maximum performance without compromising reliability, specifically engineered to meet the needs of hot data. Enterprise drives help you improve server response times, power more transactions per second and accelerate data transfer (I/O) speeds. HPE Server Enterprise Hard Drives are backed by over 2.4 million hours of the industry's most rigorous testing and qualification program ensuring customer's reliable, rugged drives. HPE integrated firmware protects data from malicious attacks that could change or destroy it. The self-describing icons on the HPE SMART Carrier takes the guess work out of a drive's status and a "do not remove" button prevents data loss from human error.
HPE Enterprise - hard drive - 600 GB - SAS 12Gb/s
Hard drive - hot-swap
600 GB
2.5" SFF
SAS 12Gb/s
Data Transfer Rate
1.2 GBps
Spindle Speed
15000 rpm
Advanced format 512n, Digitally Signed Firmware
75.7 mm x 118.7 mm x 15.6 mm
3-year warranty
Bundled with
HPE SmartDrive carrier
Nimble Storage dHCI Large Solution with HPE ProLiant DL380 Gen10, Medium Solution with HPE ProLiant DL360 Gen10, Small Solution with HPE ProLiant DL360 Gen10; ProLiant BL460c Gen10, DL160 Gen9, DL180 Gen10, DL20 Gen10, DL20 Gen9, DL325 Gen10, DL360 Gen10, DL360 Gen9, DL380 Gen10, DL380 Gen9, DL385 Gen10, DL388 Gen10, DL388 Gen9, DL560 Gen10, DL580 Gen10, DL580 Gen9, ML110 Gen10, ML110 Gen9, ML350 Gen10, XL270d Gen9; Synergy 480 Gen10, 660 Gen10
600 GB
2.5" SFF
SAS 12Gb/s
Bytes per Sector
512
75.7 mm
118.7 mm
15.6 mm
Bundled with
Performance
Drive Transfer Rate
1.2 GBps (external)
Seek Time
2.72 ms (average) / 5.36 ms (max)
Track-to-Track Seek Time
0.22 ms
Spindle Speed
15000 rpm
Expansion & Connectivity
1 x SAS 12 Gb/s
Compatible Bay
2.5" SFF
Limited warranty - 3 years
10 °C
35 °C
HPE Nimble Storage dHCI Large Solution with HPE ProLiant DL380 Gen10 (2.5"), Medium Solution with HPE ProLiant DL360 Gen10 (2.5"), Small Solution with HPE ProLiant DL360 Gen10 (2.5") , HPE ProLiant DL180 Gen10 Entry (2.5"), DL180 Gen10 SMB (2.5"), DL20 Gen10 (2.5"), DL20 Gen10 Entry (2.5"), DL20 Gen10 Performance (2.5"), DL20 Gen10 solution (2.5"), DL20 Gen9 Solution (2.5"), DL325 Gen10 Base (2.5"), DL325 Gen10 Plus (2.5"), DL325 Gen10 Plus All-NVMe Flash Node for Software Defined Storage (2.5"), DL325 Gen10 Plus for Weka Expansion Tracking (2.5"), DL325 Gen10 Solution (2.5"), DL360 Gen10 Compute Server for Cohesity DataPlatform (2.5"), DL360 Gen10 Network Choice (2.5"), DL360 Gen10 Performance for Cohesity DataPlatform (2.5"), DL360 Gen10 Remote Office Branch Office Server for Cohesity DataPlatform (2.5"), DL360 Gen10 SMB (2.5"), DL360 Gen10 SMB Network Choice (2.5"), DL360 Gen10 Solution (2.5"), DL360 Gen9 High Performance (2.5"), DL380 Gen10 All Flash Server for Datera (2.5"), DL380 Gen10 Entry SMB (2.5"), DL380 Gen10 for Cohesity DataPlatform (2.5"), DL380 Gen10 for SAP HANA Compute Block (2.5"), DL380 Gen10 Hybrid Server for Datera (2.5"), DL380 Gen10 Network Choice (2.5"), DL380 Gen10 Network Choice for CTERA (2.5"), DL380 Gen10 Network Choice for SAP HANA Compute Block (2.5"), DL380 Gen10 Server for CTERA (2.5"), DL380 Gen10 SMB (2.5"), DL380 Gen10 SMB Networking Choice (2.5"), DL380 Gen10 Solution (2.5"), DL385 Gen10 (2.5"), DL385 Gen10 High-Performance (2.5"), DL385 Gen10 Plus (2.5"), DL385 Gen10 Plus Entry (2.5"), DL385 Gen10 SMB (2.5"), DL385 Gen10 Solution (2.5"), DL388 Gen10 (2.5"), DL560 Gen10 for SAP HANA Compute Block (2.5"), DL580 Gen9 SAP HANA Scale-out Base Configuration (2.5"), ML110 Gen10 Solution (2.5"), ML350 Gen10 High Performance (2.5"), ML350 Gen10 SMB (2.5"), ML350 Gen10 Solution (2.5"), ML350 Gen10 Special Server (2.5") , HPE Synergy 480 Gen10 Plus Base Compute Module (2.5")
