Your basket is empty
HPE 600GB 10000rpm 2.5" SAS Hard Drive
Quicklinx: 8GVNWS00 Mfr#: 581311-001
Accessory Type: Hard Drive
£141.83 ex VAT
£170.19 inc VAT
600GB 2.5-inch Serial Attached SCSI (SAS) SFF 6G Dual Port Hot-Plug 10K Hard Drive in HP Hot-Plug Hard Drive tray (as pictured) for G1-G7 Proliant SAS Servers
Serial Attached SCSI (SAS) is the logical evolution of SCSI combining its long-established software advantage with the SAS electrical and physical connection. With enterprise storage requirements escalating and becoming more complex factors such as larger capacity greater density security scalability and accessibility are more critical than ever.
Hard disk drive capacity: 600 GB
Hard disk rotational speed: 10000 RPM
Hard disk interface: Serial Attached SCSI (SAS)
Hard disk size: 63.5 mm (2.5 ")
HPE Dual Port - hard drive - 600 GB - SAS 6Gb/s
Hard drive
600 GB
SAS 6Gb/s
Data Transfer Rate
600 MBps
Spindle Speed
10000 rpm
Integrity BL860c, BL860c i2, BL860c i4, BL870c i2, BL890c i2; ProLiant BL460c G6, BL460c G7, BL465c G6, BL465c G7, BL620C G7, BL680c G7, BL685c G6, BL685c G7, DL120 G7, DL160 G6, DL160se G6, DL165 G7, DL180 G6, DL320 G6, DL360 G6, DL360 G7, DL370 G6, DL380 G6, DL380 G7, DL385 G6, DL385 G7, DL580 G7, DL585 G6, DL585 G7, DL785 G6, DL980 G7, ML350 G6, ML370 G6, WS460c G6
Hard drive
600 GB
SAS 6Gb/s
Performance
Drive Transfer Rate
600 MBps (external)
Spindle Speed
10000 rpm
Expansion & Connectivity
1 x SAS 6Gb/s
Brand: HPE
Price Range Ex VAT: 100 - 150
