HPE 5510-24G-4SFP HI Switch with 1 Interface Slot - 24 ports - Managed - Rack-Mountable
Quicklinx: F6JWWS00 Mfr#: JH145A
Type: Gigabit Ethernet
Ports: 24
Managed: Yes
£5,776.01 ex VAT
£6,931.21 inc VAT
The HPE FlexNetwork 5510 HI Switch Series delivers outstanding resiliency, security, and multiservice support for medium and large enterprise networks. This switch includes enterprise-class QoS; dual, redundant power supplies with support for PoE+; 10GbE and 40GbE uplinks; 9 chassis IRF stacking; Static & RIP Routing, MACsec, OSPF, IPv6 and Energy Efficient Ethernet. The 5510 HI offers advanced technologies including OAM, CFD, multi-level QoS, MPLS, and VPLS. It can be managed with the HPE Intelligent Management Center (IMC) Software for a single view of your entire network.
  • Highly Resilient, More Secure, and Scalable Access Layer Switches
    The HPE FlexNetwork 5510 HI Switch Series delivers outstanding resiliency, security, and multiservice support capabilities for traditional large enterprise networks. Advanced technologies include OAM, CFD, RRPP, BFD, Multi-level QoS, MPLS, and VPLS.The HPE Intelligent Resilient Framework (IRF) virtualizes up to nine physical switches into one logical device for simpler, flatter, more agile networks.Offers scalable stacking with both built-in and modular 10GbE uplinks and 40GbE for high capacity, back-haul connectivity.Dual, redundant, hot-swappable power supplies keep your network up and running and deliver up to 1440 Watt of PoE+ for powered cameras, phones and wireless access points.The 5510 HI has IPv6 support and fully featured Layer 3 functionality, including RIP, OSPF, ISIS, BGP, and PIM with no software licensing required.
  • Powerful Performance
    The HPE FlexNetwork 5510 HI Switch Series provides higher levels of security with hardware-based, wire-speed access control lists (ACLs).Provides simple administration without impacting network performance offering feature-rich TCAM-based ACL implementation.Non-blocking architecture delivers up to 336 Gb/s of wire-speed switching with a non-blocking switching fabric and up to 250 million pps throughput.
  • Robust Quality of Service (QoS)
    The HPE FlexNetwork 5510 HI Switch Series supports advanced classifier-based QoS which directs traffic using multiple match criteria based on Layer 2, 3, and 4 information and applies QoS policies such as setting priority level and rate limit to selected traffic on a port, VLAN, or whole switch.Creates traffic classes based on ACLs, IEEE 802.1p precedence, IP, and DSCP or Type of Service (ToS) precedence. Supports filter, redirect, mirror, or remark.Get extensive traffic prioritization with congestion actions: strict priority (SP) queuing, weighted round robin (WRR), weighted fair queuing (WFQ), weighted random early discard (WRED), weighted deficit round robin (WDRR), SP+WDRR, and SP+WFQ.
  • Comprehensive Security Control and a Single View of the Network
    The HPE FlexNetwork 5510 HI Switch Series supports flexible authentication methods including 802.1X, MAC, and Web authentication for greater security and policy-driven application authentication.Offers identity-driven security and access control with automatic VLAN assignment and per-user ACLs allow access to specific network services without risking network security.Security features include: IP source guard, DHCPv6 snooping, STP BPDU port protection, RADIUS/HWTACACS, and SSL. Supports MACsec for greater end-point or switch-to-switch security.Can be seamlessly managed with HPE Intelligent Management Center (IMC) to provide end-to-end network transparency with consistent network experience through comprehensive configuration, compliance and policy management.RMON and sFlow provide advanced monitoring and reporting capabilities for statistics, history, alarms and events.
HPE 5510-24G-4SFP HI Switch with 1 Interface Slot - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 4 x Gigabit SFP + 4 x 10 Gigabit SFP+
Performance
Routing/switching capacity: 288 Gbps , Throughput: 214 Mpps
Jumbo Frame Support
Routing Protocol
OSPF, RIP, IS-IS, BGP, VRRP, PIM-SM, static IP routing, PIM-DM, OSPFv3, PIM-SSM, ECMP, RIPng, IS-ISv6, MPLS, Bidirectional Forwarding Detection (BFD)
Remote Management Protocol
SNMP 1, RMON, Telnet, SNMP 3, SNMP 2c, CLI
Layer 3 switching, DHCP support, ARP support, MPLS support, auto-uplink (auto MDI/MDI-X), IPv6 support, STP support, RSTP support, VRRP support, MSTP support, QoS, RRPP, ECMP, BFD, STP Root Guard, IPv4 support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.1ad, IEEE 802.1ab (LLDP)
44 cm x 36 cm x 4.37 cm
7.5 kg
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
Jumbo Frame Support
Routing Protocol
RAM
2 GB SDRAM
Flash Memory
512 MB
24 x 1000Base-T RJ-45 , 1 x console RJ-45 management
Expansion Slots
1 (total) / 1 (free) x Expansion Slot
Installed Modules Qty (Max)
0 (installed) / 1 (max)
Internal power supply (not installed)
Max Supported Qty
2
Rack Mounting Kit
Included
RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, EN 60825-1, EN 60825-2, CAN/CSA-C22.2 No. 60950-1
44 cm
36 cm
4.37 cm
7.5 kg
Limited warranty - lifetime
50 °C
5 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
F6JW HPE HP X120 SFP (mini-GBIC) Transceiver Module In Stock £132.42
F6JW HPE Premier Flex Network cable 5m Fibre Optic In Stock £35.58
Ports: 24
Managed: Yes
Brand: HPE
Price Range Ex VAT: £1500+
