HPE 5130-24G-SFP-4SFP+ EI Switch
Quicklinx: CYFLWS00 Mfr#: JG933A
Type: Gigabit Ethernet
Ports: 24
Managed: Yes
£3,660.44 ex VAT
£4,392.52 inc VAT
The HPE 5130 EI Switch Series delivers flexibility, scalability and low TCO at the access layer of medium and large enterprise campus networks. The series offers enterprise class QoS and security, Hewlett Packard Enterprise Intelligent Resilient Fabric (IRF) stacking, static layer 3 routing and RIP, convenient fixed 10GbE uplink ports, PoE+, ACLs, IPv6 and delivers energy savings with Energy Efficient Ethernet. The 5130 EI Switch Series can be managed with HPE Intelligent Management Center (IMC) for a single view of your entire network.
  • Scalable and Flexible Access Layer Switches
    The HPE 5130 EI Switch Series delivers flexibility, scalability and low TCO at the access layer of medium- and large-enterprise campus networks. The 5130 supports stacking, fixed 10GbE ports, static layer 3 routing and RIP v1/v2, PoE+, ACLs, IPv6 and power savings with Energy Efficient Ethernet.Intelligent Resilient Fabric (IRF) virtualizes up to nine physical switches into one logical device for simpler, flatter, more agile networks.Four fixed 10GbE uplinks (SFP+ and 10GBASE-T) deliver performance for bandwidth intensive applications.Includes Software-defined Network (SDN) capabilities with OpenFlow 1.3 support for future proofing your network.Limited Lifetime Warranty and no software licensing required.
  • Improved Quality of Service with Traffic Management
    The HPE 5130 EI Switch Series supports advanced classifier-based QoS which groups traffic using multiple match criteria based on Layer 2 and 3 information; applies QoS policies such as setting priority level and rate limit to selected traffic on a port, VLAN, or entire switch.Provides traffic prioritization with supported congestion actions include: strict priority (SP) queuing, weighted round robin (WRR), weighted random early detection (WRED), and SP+WRR and traffic policing with Committed Access Rate (CAR) and line rate.Reduce unwanted network traffic with broadcast control allows limitation of broadcast traffic rate to cut down on unwanted network broadcast traffic.
  • Comprehensive Security Control
    The HPE 5130 EI Switch Series supports flexible authentication methods including 802.1X and MAC Authentication for greater security and policy-driven application authentication. Per-user access control lists (ACLs) provide identity-driven security and access control.ACLs provide IP Layer 2 to Layer 4 traffic filtering; supports global ACL, VLAN ACL, port ACL, and IPv6 ACL.Security with encryption of access methods (CLI, GUI, or MIB) through SSHv2, SSL, and/or SNMPv3, and other features including DHCP protection, IP source guard, dynamic ARP protection and RADIUS/HWTACAS.
  • Single View of the Network
    The HPE 5130 EI Switch Series can be seamlessly managed with HPE Intelligent Management Center (IMC) to provide end-to-end network transparency with consistent network experience through comprehensive configuration, compliance and policy management.RMON and sFlow provide advanced monitoring and reporting capabilities for statistics, history, alarms and events.
HPE 5130-24G-SFP-4SFP+ EI - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - L3 - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x Gigabit SFP + 8 x shared 10/100/1000 + 4 x 10 Gigabit Ethernet / 1 Gigabit Ethernet SFP+
Performance
Throughput: 96 Mpps , Routing/switching capacity: 128 Gbps
IPv4 routing table entries: 512 , IPv6 routing table entries: 256
MAC Address Table Size
16384 entries
Jumbo Frame Support
9216 bytes
Routing Protocol
Static IPv4 routing, static IPv6 routing
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS, CLI
DHCP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, WRR queuing, IPv6 support, half duplex mode, full duplex mode, sFlow, RSTP support, MSTP support, ACL support, QoS, Jumbo Frames support, MLD snooping, PVST+, DLDP support, RRPP, EAD, STP Root Guard, LLDP support, DHCP relay, Port Security, dynamic ARP protection, DHCP protection, SPQ, port isolation, tagged VLAN, GARP, IRF technology
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1ad, IEEE 802.3ah, IEEE 802.1ab (LLDP)
44 cm x 36 cm x 4.36 cm
8 kg
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
16384 entries
Jumbo Frame Support
9216 bytes
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
RADIUS, TACACS+, Secure Shell v.2 (SSH2), HWTACACS
RAM
1 GB SDRAM
Flash Memory
128 MB
24 x 1000Base-X SFP , 8 x 1000Base-T RJ-45 , 4 x Gigabit / 10Gbit LAN SFP+ , 1 x serial (console) RJ-45 management
Internal power supply (not installed)
Max Supported Qty
2
60 watt
MTBF
52.79 years
FCC Class A certified, CISPR 22 Class A, CISPR 24, NOM, EN55024, EMC, RoHS, FCC CFR47 Part 15, UL 60950-1, IEC 60950-1, EN 60950-1, WEEE, ANATEL, FDA, EN 60825-1, EN 61000-4-29, ANSI C63.4-2009, VCCI V-3 Class A ITE, EN 61000-3-3:2008, VCCI V-4, EN 61000-3-2:2006+A1:2009+A2:2009, EN 61000-4-5:2006, EN 61000-4-6:2009, EN 61000-4-11:2004, EN 300 386 V1.6.1, EN55022:2010 Class A, IEC 61000-4-3:2006, EN 61000-4.4:2012, CAN/CSA-C22.2 No. 60950-1, EN 300386
44 cm
36 cm
4.36 cm
8 kg
Limited warranty - replacement - lifetime - response time: next business day , Technical support - phone consulting - 3 years
45 °C
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 95% (non-condensing)
CYFL HPE HP X120 SFP (mini-GBIC) Transceiver Module In Stock £132.42
CYFL HPE Premier Flex Network cable 5m Fibre Optic In Stock £35.58
CYFL HPE X361 150W AC Reman Power Supply In Stock £198.08
Ports: 24
Managed: Yes
Brand: HPE
Price Range Ex VAT: £1500+
