HPE 4GB 1RX8 PC4-2133P-E-15
Quicklinx: CWH3WS00 Mfr#: 805667-B21
Are you looking for enterprise-quality server memory at a lower cost? Small and medium business owners often must choose between the need for high-performance server memory that supports their workloads and the simultaneous desire to control capital and operating expenses. With HPE DDR4 Standard Memory, you don't need to choose between performance and cost efficiency. HPE Standard Memory options are designed to deliver performance, reliability and efficiency at an affordable price. Unlike third-party alternatives, HPE Standard Memory is sourced from the highest-quality DRAMS and undergoes a rigorous testing and authentication process. This extensive testing ensures that it is completely compatible with and optimized for entry-level HPE server platforms to perform to industry-defined specifications.
  • High Performance
    HPE DDR4 Standard Memory performs at industry-standard speeds.HPE DDR4 Standard Memory has built-in intelligence (advanced error detection) to improve performance, reduce downtime and lower energy costs.
  • High Reliability
    HPE DDR4 Standard Memory provides excellent quality and support for HPE ML Gen9 and DL Gen9 10/100 servers.Quality and reliability is engineered into every HPE DDR4 Standard Memory product.
  • Increased Efficiency
    HPE DDR4 Standard Memory is an affordable solution for small and medium business and remote and branch office customers.HPE DDR4 2400 MT/s Standard Memory modules reduce power consumption by up to 20% in comparison to DDR4 2133 MT/s memory modules.
HPE - DDR4 - module - 4 GB - DIMM 288-pin - 2133 MHz / PC4-17000 - unbuffered
Memory module
4 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15 (15-15-15)
Single rank, unbuffered
Voltage
1.2 V
HP 805667-B21
ProLiant DL20 Gen9, DL20 Gen9 Base, DL20 Gen9 Entry, DL20 Gen9 Performance, DL20 Gen9 Solution, DL20 Gen9 Special Server, ML10 Gen9, ML10 Gen9 Entry, ML10 Gen9 Performance, ML30 Gen9, ML30 Gen9 Base, ML30 Gen9 Entry, ML30 Gen9 Performance, ML30 Gen9 Solution
4 GB
Upgrade Type
System specific
HP 805667-B21
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL15 (15-15-15)
ECC
Chips Organization
X8
Voltage
1.2 V
Colour Category
Green
HPE ProLiant DL20 Gen9, DL20 Gen9 Base, DL20 Gen9 Entry, DL20 Gen9 Performance, DL20 Gen9 Solution, DL20 Gen9 Special Server, ML10 Gen9, ML10 Gen9 Entry, ML10 Gen9 Performance, ML30 Gen9, ML30 Gen9 Base, ML30 Gen9 Entry, ML30 Gen9 Performance, ML30 Gen9 Solution
