Maximize your business PC performance with HP Memory. Upgrading your memory is a cost-effective way to boost your system performance without having to upgrade your processor.
- Dual channel configuration - HP Desktops feature motherboards designed with two memory channels instead of a single channel.
- Reduce system latencies and significantly improve your system performance with dual channel memory configurations by utilizing the theoretical bandwidth of two memory modules instead of one.
- Expect fast start-up times with reduced delays during routine operations and system maintenance functions. Meet everyday workloads head on, and run more programs simultaneously. Easily toggle back and forth between several open applications with noticeable speed.
- Your performance is our business. Each HP Memory model undergoes a rigorous supplier qualification processes for ensured quality and reliability in a variety of networked environments.
- Dual Channel memory configuration requires the population of symmetric memory in each of the two memory channels (i.e. 2x256).
- HP - DDR3 - module - 4 GB - SO-DIMM 204-pin - 1600 MHz / PC3-12800 - unbuffered
- Product Type
- Memory module
- Capacity
- 4 GB
- Memory Type
- DDR3 SDRAM - SO-DIMM 204-pin
- Upgrade Type
- System specific
- Data Integrity Check
- Non-ECC
- Speed
- 1600 MHz (PC3-12800)
- Unbuffered
- Designed For
- Compaq CQ58; Presario CQ42, CQ57, CQ58, CQ62; Pavilion Laptop dm1, dv3, dv5, dv6, dv7
- Capacity
- 4 GB
- Upgrade Type
- System specific
- DRAM memory module
- Technology
- DDR3 SDRAM
- Form Factor
- SO-DIMM 204-pin
- Speed
- Non-ECC
- Unbuffered
- Compatible Slots
- 1 x memory - SO-DIMM 204-pin
- Designed For
- Compaq CQ58-200SG, CQ58-200SO, CQ58-201SG, CQ58-202SD, CQ58-202SS, CQ58-202TU, CQ58-203SD, CQ58-206SD, CQ58-206SL, CQ58-210SW, CQ58-215EW, CQ58-216SL, CQ58-217SL, CQ58-218SL, CQ58-219SL, CQ58-221SL, CQ58-222SL, CQ58-225EL, CQ58-225SL, CQ58-230SF, CQ58-237SF, CQ58-250EC, CQ58-250SC, CQ58-250SG, CQ58-251SH, CQ58-252SA, CQ58-252SS, CQ58-253SS, CQ58-260EA, CQ58-261EA, CQ58-270SO, CQ58-271SD, CQ58-276SD, CQ58-282SG, CQ58-295EG, CQ58-300SA, CQ58-300SB, CQ58-300SW, CQ58-301SL, CQ58-301SS, CQ58-301SW, CQ58-302SA, CQ58-302SP, CQ58-303SD, CQ58-303SO, CQ58-304SA, CQ58-305EW, CQ58-305SA, CQ58-306SD, CQ58-307SL, CQ58-311SL, CQ58-313ES, CQ58-313SS, CQ58-319EW, CQ58-320EW, CQ58-325SR, CQ58-330SF, CQ58-347SG, CQ58-350SG, CQ58-351EO, CQ58-351SC, CQ58-351SO, CQ58-353SO, CQ58-373SD, CQ58-392SG, CQ58-bf9WM, CQ58-d01SA, CQ58-d28SA, CQ58-d36SF, CQ58-d50SO, CQ58-d56SR , Compaq Presario CQ57-386NR, CQ57-420SW, CQ57-430SW, CQ57-431SC, CQ57-441SL, CQ58-100SF, CQ58-100SH, CQ58-124SZ, CQ58-135SW, CQ58-145SW, CQ58-150SL , HP Pavilion Laptop dm1-4340sf, dv6-3048sa, dv6-3137s, dv6-3156ef, dv6-3232nr, dv6-3240us, dv7-4020em, dv7-4020es, dv7-4030em, dv7-4030si, dv7-4033tx, dv7-4060si, dv7-4077cl, dv7-4100em, dv7-4103sg, dv7-4105sw, dv7-4109eg, dv7-4110sw, dv7-4111ez, dv7-4119sz, dv7-4120em, dv7-4120ew, dv7-4130ew, dv7-4139eo, dv7-4140ef, dv7-4140ew, dv7-4141eb, dv7-4141ed, dv7-4141sa, dv7-4143ea, dv7-4143ed, dv7-4150ed, dv7-4150em, dv7-4150sg, dv7-4152ef, dv7-4156sg, dv7-4157sg, dv7-4158sg, dv7-4160sf, dv7-4161sf, dv7-4161ss, dv7-4165dx, dv7-4167ef, dv7-4168sf, dv7-4169ef, dv7-4170eg, dv7-4170ss, dv7-4171sf, dv7-4172sf, dv7-4174sf, dv7-4177nr, dv7-4190ef, dv7-4269wm, dv7-4270us, dv7-4285dx, dv7-4288ca, dv7-4294nr, dv7-4295us, dv7-4296nr, dv7-4300el, dv7-4301sg, dv7-4310ef, dv7-4310sf, dv7-4320el, dv7-4350ec, dv7-4362ef, dv7-4362sf, dv7-4372ef, dv7-4380es, dv7-4381eg, dv7-4381sg, dv7-5003tx, dv7-5004tx, dv7-5005tx, dv7-5050es, dv7-5070ca, dv7-5090ef
