HPE 4GB 1600MHz PC3-12800 SO DIMM 204-pin Unbuffered non-ECC Memory Module
Quicklinx: B9Y9WS00 Mfr#: 641369-001
Type: DDR3 SDRAM
Capacity: 4GB
Connection: SO-DIMM 204-pin
Speed: 1600MHz
Registered/Buffered: Unbuffered
£84.76 ex VAT
£101.71 inc VAT
Maximize your business PC performance with HP Memory. Upgrading your memory is a cost-effective way to boost your system performance without having to upgrade your processor.
  • Dual channel configuration - HP Desktops feature motherboards designed with two memory channels instead of a single channel.
  • Reduce system latencies and significantly improve your system performance with dual channel memory configurations by utilizing the theoretical bandwidth of two memory modules instead of one.
  • Expect fast start-up times with reduced delays during routine operations and system maintenance functions. Meet everyday workloads head on, and run more programs simultaneously. Easily toggle back and forth between several open applications with noticeable speed.
  • Your performance is our business. Each HP Memory model undergoes a rigorous supplier qualification processes for ensured quality and reliability in a variety of networked environments.
  • Dual Channel memory configuration requires the population of symmetric memory in each of the two memory channels (i.e. 2x256).
HP - DDR3 - module - 4 GB - SO-DIMM 204-pin - 1600 MHz / PC3-12800 - unbuffered
Memory module
4 GB
Memory Type
DDR3 SDRAM - SO-DIMM 204-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3-12800)
Unbuffered
Compaq CQ58; Presario CQ42, CQ57, CQ58, CQ62; Pavilion Laptop dm1, dv3, dv5, dv6, dv7
4 GB
Upgrade Type
System specific
DRAM memory module
DDR3 SDRAM
SO-DIMM 204-pin
Speed
Non-ECC
Unbuffered
Compatible Slots
1 x memory - SO-DIMM 204-pin
Compaq CQ58-200SG, CQ58-200SO, CQ58-201SG, CQ58-202SD, CQ58-202SS, CQ58-202TU, CQ58-203SD, CQ58-206SD, CQ58-206SL, CQ58-210SW, CQ58-215EW, CQ58-216SL, CQ58-217SL, CQ58-218SL, CQ58-219SL, CQ58-221SL, CQ58-222SL, CQ58-225EL, CQ58-225SL, CQ58-230SF, CQ58-237SF, CQ58-250EC, CQ58-250SC, CQ58-250SG, CQ58-251SH, CQ58-252SA, CQ58-252SS, CQ58-253SS, CQ58-260EA, CQ58-261EA, CQ58-270SO, CQ58-271SD, CQ58-276SD, CQ58-282SG, CQ58-295EG, CQ58-300SA, CQ58-300SB, CQ58-300SW, CQ58-301SL, CQ58-301SS, CQ58-301SW, CQ58-302SA, CQ58-302SP, CQ58-303SD, CQ58-303SO, CQ58-304SA, CQ58-305EW, CQ58-305SA, CQ58-306SD, CQ58-307SL, CQ58-311SL, CQ58-313ES, CQ58-313SS, CQ58-319EW, CQ58-320EW, CQ58-325SR, CQ58-330SF, CQ58-347SG, CQ58-350SG, CQ58-351EO, CQ58-351SC, CQ58-351SO, CQ58-353SO, CQ58-373SD, CQ58-392SG, CQ58-bf9WM, CQ58-d01SA, CQ58-d28SA, CQ58-d36SF, CQ58-d50SO, CQ58-d56SR , Compaq Presario CQ57-386NR, CQ57-420SW, CQ57-430SW, CQ57-431SC, CQ57-441SL, CQ58-100SF, CQ58-100SH, CQ58-124SZ, CQ58-135SW, CQ58-145SW, CQ58-150SL , HP Pavilion Laptop dm1-4340sf, dv6-3048sa, dv6-3137s, dv6-3156ef, dv6-3232nr, dv6-3240us, dv7-4020em, dv7-4020es, dv7-4030em, dv7-4030si, dv7-4033tx, dv7-4060si, dv7-4077cl, dv7-4100em, dv7-4103sg, dv7-4105sw, dv7-4109eg, dv7-4110sw, dv7-4111ez, dv7-4119sz, dv7-4120em, dv7-4120ew, dv7-4130ew, dv7-4139eo, dv7-4140ef, dv7-4140ew, dv7-4141eb, dv7-4141ed, dv7-4141sa, dv7-4143ea, dv7-4143ed, dv7-4150ed, dv7-4150em, dv7-4150sg, dv7-4152ef, dv7-4156sg, dv7-4157sg, dv7-4158sg, dv7-4160sf, dv7-4161sf, dv7-4161ss, dv7-4165dx, dv7-4167ef, dv7-4168sf, dv7-4169ef, dv7-4170eg, dv7-4170ss, dv7-4171sf, dv7-4172sf, dv7-4174sf, dv7-4177nr, dv7-4190ef, dv7-4269wm, dv7-4270us, dv7-4285dx, dv7-4288ca, dv7-4294nr, dv7-4295us, dv7-4296nr, dv7-4300el, dv7-4301sg, dv7-4310ef, dv7-4310sf, dv7-4320el, dv7-4350ec, dv7-4362ef, dv7-4362sf, dv7-4372ef, dv7-4380es, dv7-4381eg, dv7-4381sg, dv7-5003tx, dv7-5004tx, dv7-5005tx, dv7-5050es, dv7-5070ca, dv7-5090ef
Type: DDR3 SDRAM
Capacity: 4GB
Speed: 1600MHz
Brand: HPE
