Boost the capabilities of your HP Workstation and newest multi-core processors. Choose ultra-fast 2 GB, 4 GB, 8 GB, or 16 GB 1866 MHz DDR3 memory from HP, a cost-effective way to improve system performance and application responsiveness.
- HP - DDR3 - module - 4 GB - DIMM 240-pin - 1866 MHz / PC3-14900 - registered
- Product Type
- Memory module
- Capacity
- 4 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 1866 MHz (PC3-14900)
- Registered
- OEM Manufacturer Equivalent Part Number
- HP E2Q92AA
- Pricing Type
- CTO
- Designed For
- Workstation Z620, Z820
- Capacity
- 4 GB
- Upgrade Type
- System specific
- HP E2Q92AA
- DRAM memory module
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- ECC
- Registered
- Chips Organization
- 512 x 4
- Compatible Slots
- 1 x memory - DIMM 240-pin
- Pricing Type
- CTO
- Designed For
- HP Workstation Z620, Z820
