Power supply for use with HP 3xx Cloud-Managed Access Points where PoE is not available.
Dimensions and weight:
Minimum dimensions (W x D x H)
9.4 x 3.81 x 3 cm
0.4 kg
Designed For:
HPE 103 Instant, 205 Instant, 215 Instant, 225 Instant, 350 Cloud-Managed Access Point, 355, 355 Cloud-Managed Access Point
Efficient power supply
Designed for seamless compatibility with PCs, this external power adapter ensures your device remains powered up and operational. Its external form factor allows for easy installation and removal, making it a convenient solution for dynamic work environments. -
Reliable performance
Crafted by Hewlett Packard Enterprise, this power adapter is built to deliver reliable performance. It's specifically engineered to meet the power needs of your device, ensuring a steady and uninterrupted power supply.
- HPE - power adapter
- Power adapter - external
- 400 g
- Included Accessories
- 8 power plug adapters
- 9.4 cm x 3.81 cm x 3 cm
- Designed For
- HPE 103 Instant, 205 Instant, 215 Instant, 225 Instant, 350 Cloud-Managed Access Point, 355, 355 Cloud-Managed Access Point
- 9.4 cm
- 3.81 cm
- 3 cm
- 400 g
- Designed For
- HPE 103 Instant (US), 103 Instant (WW), 205 Instant (US), 205 Instant (WW), 215 Instant (US), 215 Instant (WW), 225 Instant (US), 225 Instant (WW), 350 Cloud-Managed Access Point (JP), 350 Cloud-Managed Access Point (US), 350 Cloud-Managed Access Point (WW), 355 (WW), 355 Cloud-Managed Access Point (JP), 355 Cloud-Managed Access Point (US)
