HPE 32GB (1x32GB) DDR3-1866 ECC Reg RAM
Quicklinx: 9RGCWS00 Mfr#: F1F33AA
Boost the capabilities of your HP Workstation and newest multi-core processors with ultra-fast HP 32 GB (1 x 32 GB) DDR3-1866 ECC LR RAM, a cost-effective way to improve system performance and application responsiveness.
  • Maximize the newest processors
    Keep the newest multi-core processors performing at their peak with ultra-fast 1866 MHz memory. Improve start-up times with fewer delays during routine operations, run more programs simultaneously, and easily toggle between several open applications.
  • Benefit from integrated ECC
    Help avoid errors that can corrupt data sets and introduce system issues with Error Correcting and Checking technology that corrects single-bit memory errors.
  • Get HP-tested reliability
    Ensure all of your memory characteristics match by upgrading with HP-branded memory that's tested to work seamlessly with HP products.
HP - DDR3 - module - 32 GB - LRDIMM 240-pin - 1866 MHz / PC3-14900 - LRDIMM
Memory module
32 GB
Memory Type
DDR3 SDRAM - LRDIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1866 MHz (PC3-14900)
Load-Reduced
Voltage
1.5 V
HP F1F33AA
1-year warranty
Workstation Z820
32 GB
Upgrade Type
System specific
HP F1F33AA
DRAM memory module
DDR3 SDRAM
LRDIMM 240-pin
Speed
ECC
Load-Reduced
Chips Organization
1024 x 4
Voltage
1.5 V
1-year warranty
HP Workstation Z820
