HPE 2TB RDX Removable Disk Cartridge
Reduced to clear!
Clearance
Last Few Remaining
Quicklinx: 9ZNTWS00 Mfr#: Q2046A
Type: Disk drive
Controller Type: [N/A]
More than 50 in stock
£289.46 ex VAT
£347.35 inc VAT
Does your budget-conscious small business have little or no IT resources with rudimentary backup processes in place? The HP RDX Removable Disk Cartridge delivers an easy-to-use, affordable, rugged and removable data protection cartridge for servers and workstations. Backups are simple and pain-free with drag and drop file access. Fast disk based performance provides the ability to store, 320 GB, 500 GB, 1 TB or 2 TB of data on a single removable disk cartridge at speeds of up to 360 GB/hr. Long lasting removable disk cartridges and forward and backward compatible RDX docking station reduces ownership cost. When used with an HP RDX Backup System the solution seamlessly integrates with HP Continuous Data Protection Software providing complete data protection and enabling simple and secure off-site storage.
  • Outstanding Reliability and Durability
    The HPE RDX Removable Disk Cartridge is designed for over 5,000 load and unload cycles and designed for long life expectancy.Cartridges are tested to withstand a drop of 1 meter (39.4 in) making them more reliable for easy transport and store off-site for disaster recovery.These rugged, portable cartridges protect the hard drive inside supporting making transporting data between locations easy and more reliable.
  • Business Class Design Features
    The HPE RDX Removable Disk Cartridge has built-in static protection reducing server failures due to statically charged peripherals.Inner buffers designed to lower vibration for better read/write disk performance.Supports disk spanning so backup data can continue to grow across multiple cartridges.Fixed disk mode capabilities offering easy server operating system integration in a small business environment.
  • Easy to Own and Manage
    Each HPE RDX Removable Disk Cartridge is qualified and tested making it easy to integrate into your server, storage and networking environments.Compatibility across various operating systems and virtualization platforms makes it simple to adapt into any small business environment.Fixed disk mode capabilities offering easy automated backups via the native Microsoft Windows OS.
HPE - RDX x 1 - 2 TB - storage media
Storage media - RDX
Media Included Qty
1
Native Capacity
2 TB
Compressed Capacity
4 TB
1-year warranty
RDX
Media Included Qty
1
Media
Native Capacity
2 TB
Compressed Capacity
4 TB
1-year warranty
5 °C
45 °C
20 - 80% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
65 °C
Type: Disk drive
Brand: HPE
Price Range Ex VAT: 150 - 300
