HPE 2GB PC3-10600 DDR3-1333 DIMM M
HP 2-GB PC3-10600 (DDR3-1333 MHz) DIMM
Quicklinx: 6Z8BWS00 Mfr#: AT024AT
Maximize your Business PC performance with HP Memory. Upgrading your memory is a cost-effective way to boost your system performance without having to upgrade your processor.
- Faster start-up times with fewer delays during routine operations
- More programs running simultaneously
- Easy toggling between several open applications
- Rigorous supplier qualification processes for ensured quality
- Thoroughly tested by HP for high reliability
HP - DDR3 - module - 2 GB - DIMM 240-pin - 1333 MHz / PC3-10600 - unbuffered
Memory module
2 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
1333 MHz (PC3-10600)
Unbuffered
Manufacturer Selling Program
HP Smart Buy
HP 4000 Pro, 500B, 505B, 6000 Pro, 6005 Pro, 6200 Pro, 8200 Elite, Elite 8000, Elite 8100; Business Desktop dx7510; Elite 7000, 7100, 7200; MultiSeat ms6000, ms6200; Point of Sale System rp5800; Pro 2000, 3000, 3005, 3010, 3015, 3090, 3120, 3125, 3130, 3135, 3300, 3305, 3400
2 GB
Upgrade Type
System specific
DRAM memory module
DDR3 SDRAM
DIMM 240-pin
Speed
Non-ECC
Unbuffered
HP Smart Buy
HP 500B , HP Elite 7000, 7100, 7200 , HP MultiSeat ms6000, ms6200 , HP Point of Sale System rp5800 , HP Pro 2000, 3000, 3005, 3010, 3015, 3090, 3120, 3125, 3130, 3135, 3300, 3305, 3400 , HP Compaq 4000 Pro, 500B, 505B, 6000 Pro, 6005 Pro, 6200 Pro, 8200 Elite, Elite 8000, Elite 8100 , HP Compaq Business Desktop dx7510
