Is finding reliable DRAM memory for your HP ProLiant Gen8 Server series in your data center a major challenge? When you choose HP SmartMemory you get the same high quality, reliability, and confidence that come with your HP ProLiant Gen8 Server series. DRAM quality and reliability are more important now than ever. Industry trends such as server virtualization, cloud computing, the use of large database applications, and high-performance computing have all created demand for higher capacity memory with greater reliability and uptime. HP SmartMemory unlocks certain features available only with HP Qualified Server memory. HP SmartMemory enables ProLiant Gen8 Servers to reliably identify and verify whether installed memory has passed the rigorous HP qualification and testing processes. And because the memory is authenticated, you can enable extended memory performance features through the system ROM.
High Performance
HPE DDR3 SmartMemory performs to industry-defined specifications.HPE DDR3 SmartMemory has been tested and performance-tuned specifically for HPE ProLiant Server series, which ensures that HPE server memory is optimized for every HPE server.HPE DDR3 SmartMemory enables extended memory performance features through the system ROM. -
High Reliability
HPE DDR3 SmartMemory is made of the highest quality materials, reducing issues that affect signal integrity and increasing system reliability. -
Improved Efficiency
HPE DDR3 SmartMemory supports HPE servers at a lower price point.
- HPE - DDR3 - module - 2 GB - DIMM 240-pin - 1333 MHz / PC3-10600 - registered
- Product Type
- Memory module
- Capacity
- 2 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 1333 MHz (PC3-10600)
- Latency Timings
- CL9
- Dual rank, registered
- Designed For
- ProLiant BL620C G7, BL680c G7, DL360 G7, DL370 G6, DL380 G6, DL380 G7, SL160s G6, SL390s G7, WS460c G6; StorageWorks Network Storage Blade X1800sb G2; StorageWorks Network Storage Gateway X3400 G2, X3800 G2, X3800sb G2; StorageWorks Network Storage System X1400 G2, X1500 G2, X1600 G2, X1800 G2
- Capacity
- 2 GB
- Upgrade Type
- System specific
- DRAM memory module
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- Latency Timings
- CL9
- ECC
- Compatible Slots
- 1 x memory - DIMM 240-pin
- Designed For
- HPE ProLiant BL2x220c G7, BL460c G7, BL490c G7, BL620C G7, BL680c G7, DL360 G7 Central Management Server, DL360 G7 Efficiency, DL360 G7 Special Server, DL370 G6 High Performance, DL370 G6 Special Server, DL380 G6, DL380 G6 Special Rack Server, DL380 G7 Special Server, DL980 G7, SL160s G6, SL170s G6 1U Left Half Width tray, SL170s G6 1U Right Half Width tray, SL170s G6 Base 1U Left Half Width tray, SL170s G6 Base 1U Right Half Width tray, SL170s G6 Entry 1U Left Half Width tray, SL170s G6 Entry 1U Right Half Width tray, SL170s G6 Performance 1U Left Half Width tray, SL170s G6 Performance 1U Right Half Width tray, SL390s G7, SL390s G7 1U Left Half Width tray, SL390s G7 1U Left Tray Node Server, SL390s G7 1U Right Half Width tray, SL390s G7 1U Right Tray Node Server, SL390s G7 2U Left Half Tray Node Server, SL390s G7 2U Right Half Width tray, SL390s G7 4U Left Half Width tray, SL390s G7 4U Left Tray Node Server, SL390s G7 4U Right Half Width tray, SL390s G7 4U Right Tray Node Server, SL390s G7 Base 1U left Half Width tray, SL390s G7 Base 1U Right Half Width tray, SL390s G7 Base 2U Left Half Width tray, SL390s G7 Base 2U Right Half Width tray, SL390s G7 Base 4U Left Half Width tray, SL390s G7 Base 4U Right Half Width tray, SL390s G7 Entry 1U Left Half Width tray, SL390s G7 Entry 1U Right Half Width tray, SL390s G7 Entry 2U Left Half Width tray, SL390s G7 Entry 2U Right Half Width tray, SL390s G7 Performance 1U left Half Width tray, SL390s G7 Performance 1U Right Half Width tray, SL390s G7 Performance 2U Left Half Width tray, SL390s G7 Performance 2U Right Half Width tray, SL390s G7 Performance 4U Left Half Width tray, SL390s G7 Performance 4U Right Half Width tray, WS460c G6 Workstation , HPE StorageWorks Network Storage Blade X1800sb G2 , HPE StorageWorks Network Storage Gateway X3400 G2, X3800 G2, X3800sb G2 , HPE StorageWorks Network Storage System X1400 G2, X1500 G2, X1600, X1600 G2, X1800, X1800 G2
