HPE 2GB DDR3-1600 ECC RAM
Quicklinx: 8Q0MWS00 Mfr#: A2Z47AT
2GB (1x2GB configuration) of DDR3-1600 ECC Unbuffered DIMMs. Boost the capabilities of your HP Workstation and keep it performing reliably with HP memory. Upgrading your memory is a cost-effective way to improve system performance when insufficient memory and hard drive paging is slowing your applications down.
HP - DDR3 - module - 2 GB - DIMM 240-pin - 1600 MHz / PC3-12800 - unbuffered
Memory module
2 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1600 MHz (PC3-12800)
Unbuffered
Manufacturer Selling Program
HP Smart Buy
Workstation Z1, Z220, Z230, Z420, Z620
2 GB
Upgrade Type
System specific
DRAM memory module
DDR3 SDRAM
DIMM 240-pin
Speed
ECC
Unbuffered
Compatible Slots
1 x memory - DIMM 240-pin
HP Smart Buy
HP Workstation Z1, Z220, Z230, Z420, Z620
