Maximize your business PC performance with HP Memory. Upgrading your memory is a cost-effective way to boost your system performance without having to upgrade your processor.
- HP - DDR3 - module - 2 GB - DIMM 240-pin - 1600 MHz / PC3-12800 - unbuffered
- Product Type
- Memory module
- Capacity
- 2 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- Non-ECC
- Speed
- 1600 MHz (PC3-12800)
- Unbuffered
- Manufacturer Selling Program
- HP Smart Buy
- 1-year warranty
- Designed For
- HP 280 G1, 6300 Pro, 6305 Pro, Elite 8300 (DIMM)
- Capacity
- 2 GB
- Upgrade Type
- System specific
- DRAM memory module
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Module Height (inch)
- 1.18
- Speed
- Non-ECC
- Unbuffered
- Compatible Slots
- 1 x memory - DIMM 240-pin
- HP Smart Buy
- 1-year warranty
- Designed For
- HP 280 G1 , HP Compaq 6300 Pro, 6305 Pro, Elite 8300 (DIMM)
