HPE 2GB DDR3-1600 DIMM
Quicklinx: 8V3JWS00 Mfr#: B4U35AT
Maximize your business PC performance with HP Memory. Upgrading your memory is a cost-effective way to boost your system performance without having to upgrade your processor.
HP - DDR3 - module - 2 GB - DIMM 240-pin - 1600 MHz / PC3-12800 - unbuffered
Memory module
2 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3-12800)
Unbuffered
Manufacturer Selling Program
HP Smart Buy
1-year warranty
HP 280 G1, 6300 Pro, 6305 Pro, Elite 8300 (DIMM)
2 GB
Upgrade Type
System specific
DRAM memory module
DDR3 SDRAM
DIMM 240-pin
Module Height (inch)
1.18
Speed
Non-ECC
Unbuffered
Compatible Slots
1 x memory - DIMM 240-pin
HP Smart Buy
1-year warranty
HP 280 G1 , HP Compaq 6300 Pro, 6305 Pro, Elite 8300 (DIMM)
