HPE 2GB, PC2-3200, DDR2, SDRAM
Quicklinx: 7LBSWS00 Mfr#: 413386-001
Genuine HPE 2GB PC2-3200 DDR2 400MHz 240-pin SDRAM Memory Stick
Specifications:
Category: Proliant Memory
Sub-Category: PC2-3200
Generation: 400MHz
Technology: DDR2 SDRAM
Capacity: 2GB
Form Factor: DIMM 240-pin
Integral - DDR - module - 2 GB - DIMM 184-PIN - 400 MHz / PC3200 - registered
Memory module
2 GB
Memory Type
DDR SDRAM - DIMM 184-PIN
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
400 MHz (PC3200)
Latency Timings
CL3
Dual rank, registered
Voltage
2.5 V
HPE ProLiant DL380 G4, DL380 G4 High Performance, DL580 G3, DL580 G3 High Performance, ML350 G4p, ML370 G4, ML370 G4 High Performance, ML570 G3, ML570 G3 High Performance, ML570 G4, ML570 G4 High Performance
2 GB
Upgrade Type
System specific
DRAM memory module
DDR SDRAM
DIMM 184-PIN
Speed
400 MHz (PC3200)
Latency Timings
CL3
ECC
Module Configuration
256 x 72
Chips Organization
128 x 4
Voltage
2.5 V
Compatible Slots
1 x memory - DIMM 184-PIN
