HPE 2GB (1x2GB) DDR3-1866 MHz ECC RAM
Quicklinx: BFBYWS00 Mfr#: E2Q90AA
Boost the capabilities of your HP Workstation and newest multi-core processors. Choose ultra-fast 2 GB, 4 GB, 8 GB, or 16 GB 1866 MHz DDR3 memory from HP, a cost-effective way to improve system performance and application responsiveness.
HP - DDR3 - module - 2 GB - DIMM 240-pin - 1866 MHz / PC3-14900 - unbuffered
Memory module
2 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1866 MHz (PC3-14900)
Unbuffered
1-year warranty
Workstation Z1 G2, Z420, Z620, Z820
2 GB
Upgrade Type
System specific
DRAM memory module
DDR3 SDRAM
DIMM 240-pin
Speed
ECC
Unbuffered
Compatible Slots
1 x memory - DIMM 240-pin
1-year warranty
HP Workstation Z1 G2, Z420, Z620, Z820
