2GB (1x2GB configuration) of DDR3-1600 ECC Unbuffered DIMMs. Boost the capabilities of your HP Workstation and keep it performing reliably with HP memory. Upgrading your memory is a cost-effective way to improve system performance when insufficient memory and hard drive paging is slowing your applications down.
- HP - DDR3 - module - 2 GB - DIMM 240-pin - 1600 MHz / PC3-12800 - unbuffered
- Product Type
- Memory module
- Capacity
- 2 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 1600 MHz (PC3-12800)
- Unbuffered
- OEM Manufacturer Equivalent Part Number
- HP A2Z47AA
- Designed For
- Workstation Z1, Z220, Z230, Z420, Z620, Z820
- Capacity
- 2 GB
- Upgrade Type
- System specific
- HP A2Z47AA
- DRAM memory module
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- ECC
- Unbuffered
- Compatible Slots
- 1 x memory - DIMM 240-pin
- Designed For
- HP Workstation Z1, Z220, Z230, Z420, Z620, Z820
