Your basket is empty
HPE 256GB SATA SED Solid State Drive
Quicklinx: 9RGHWS00 Mfr#: A3D26AT
Solid State Drives (SSDs) are fast becoming a real force with respect to storage in the computer industry. With no moving parts, storage is no longer bound by mechanical barriers to higher performance. HP SSDs for workstations offer overall performance typcially beyond that of SAS 15k rpm HDDs (Hard Disk Drives).
HP - solid state drive - 256 GB - SATA 6Gb/s
Solid state drive - internal
256 GB
2.5" SFF (in 3.5" carrier)
SATA 6Gb/s
Data Transfer Rate
600 MBps
6.36 cm x 6.99 cm x 9.5 mm
Workstation Z1, Z1 G3, Z2 Mini G3 Entry, Z2 Mini G3 Performance, z210, Z220, Z230, Z238, z400, Z420, z600, Z620, Z640, Z8 G4, z800, Z820
256 GB
2.5" SFF
SATA 6Gb/s
6.36 cm
6.99 cm
9.5 mm
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
500 MBps
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5" SFF or 3.5" (with included bay adapter)
3.5-inch bay adapter
70 °C
HP Workstation Z1, Z1 G3, Z2 Mini G3 Entry, Z2 Mini G3 Performance, z210, Z220, Z230, Z238, z400, Z420, z600, Z620, Z640, Z8 G4, z800, Z820
