With HPE Non-custom Labeled LTO Ultrium media, you no longer have to label your own cartridges, saving you time and the risk of retrieval errors. Barcode sequences are unique to each batch ordered – no codes are repeated. HPE rigorously tests its precision-engineered, high-resolution barcode labels using software unique to the HPE Automation Group to evaluate and warrant the performance of its labels in demanding, split-second datacenter environments. These labels are professionally applied in a clean environment to ensuring 100% readability accurate storage. Non-Custom Labeled cartridges ensure 100% label readability and can be ordered online, in packs of 20, using a fast and simple process. For those customer who value the added security that RFID adds, customers have the option to integrate it into each label at minimal cost. The RFID tag is embedded into the back of the non-custom label and offers tracking, audit and security advantages for those with IT asset tracking systems.
Highest Capacity and Performance of any Comparable Tape Technology
HPE LTO-8 Ultrium can write or read data at a blistering 2.7 TB/hour, storing, encrypting and protecting up to 30 TB on a single cartridge, making it ideal for large-scale, 24 x 7, mission-critical IT environments (assumes 2.5:1 compression).An 85% increase in the number of tracks and a 8% increase in bit density has permitted an increase in capacity from 15 TB for LTO-7 to 30 TB to LTO-8: from 3,584 tracks for LTO-6 to 6,656 tracks for 8th generation HPE LTO-8 Ultrium 30 TB cartridges (assuming 2.5:1 compression).HPE LTO Ultrium cartridge memory chip delivers faster access time and enhanced media monitoring.First time restore ensured with fewer media failures and disrupted backups, regardless of duty cycle or environmental conditions. -
Ultra-reliable
Tape is more reliable than Enterprise SATA disk. With a BER of 1x10 to the power of 19 for LTO-8 versus 1x10 to the power of 15 for Enterprise SATA HDD's. That's a difference in reliability of four orders of magnitude – e.g. tape is 10,000 times more reliable than Enterprise SATA HDD.Estimated data loss over 10 years for 1 Exabyte archive is 1.1 Petabytes for HDD compared to only 7.4 Terabytes for tape.Superior 'smart grabber' mechanism and mechanical interlock to prevent the leader pin from being pulled inside the tape housing. Sensors detect proper connection and prevent leader loss that would ruin the tape. Simplified tape path to reduce wear, tear & build-up of debris (important in automation).HPE brand qualification test procedures (load/unload, shoeshine, drop testing and environmental stress testing) go far beyond what is required for the LTO Ultrium logo.This ensures maximum reliability for restoring your data.HPE warrants LTO Ultrium cartridges for up to 30 years archival life. This ensures businesses can meet the ever-increasing demands of regulation for data retention and archiving. -
Secure
Write-Once-Read-Many (WORM) version provides tamper-proof, compliant data storage.Data encryption for enhanced data security on HPE LTO-4, LTO-5, LTO-6, LTO-7 and LTO-8 Ultrium. Compliance with FIPS 140-2 level 1 security standards. -
Value for money
Standardizing on HPE LTO Ultrium delivers the capacity to meet shrinking backup windows, industry-standard, AES 256-bit encryption (IEEE1619.1), and interchangeable RW or WORM media; without extra space or IT resource overhead.Open standard technology ensures compatibility across product generations and gives you more choice. Cartridges are available as Custom Labeled, Non-Custom Labeled (both Custom and Non Custom include RFID options for some formats) and non-labeled versions.
 - HPE - LTO Ultrium 3 x 20 - 400 GB - storage media
 - Storage media - LTO Ultrium
- Tape Cartridge
 - Ultrium 3
- Media Included Qty
 - 20
- Native Capacity
 - 400 GB
- Compressed Capacity
 - 800 GB
- Tape Length
 - 680 m
- Cartridge Labeling
 - Labeled
 - Limited lifetime warranty
- Designed For
 - StorageWorks ESL9000, ESL9198, ESL9198SL, ESL9322, ESL9322L1, ESL9322L2, ESL9322S2, ESL9326, ESL9326D, ESL9326SL, ESL9595, ESL9595L1, ESL9595L2, ESL9595S2, ESL9595SL, MSL2024, MSL4048, MSL6030, MSL6060, SAS Rack-Mount Kit, SSL1016; StorageWorks 1/8 G2 Tape Autoloader; StorageWorks Ultrium 920
 - LTO Ultrium
- Tape Cartridge
 - Ultrium 3
 - 20
 - Labeled
Media
- Native Capacity
 - 400 GB
 - 800 GB
- Tape Length
 - 680 m
- Archival Life
 - 30 years
 - 10 °C
 - 45 °C
 - 10 - 80%
- Designed For
 - HPE StorageWorks ESL9000, ESL9198, ESL9198SL, ESL9322, ESL9322L1, ESL9322L2, ESL9322S2, ESL9326, ESL9326D Enterprise Library, ESL9326SL, ESL9595, ESL9595L1, ESL9595L2, ESL9595S2, ESL9595SL, MSL2024 Ultrium 960, MSL4048, MSL4048 Ultrium 960, MSL6030 Ultrium 960, MSL6060 Ultrium 960, SAS Rack-Mount Kit, SSL1016, SSL1016 Tape Autoloader , HPE StorageWorks 1/8 G2 Tape Autoloader Ultrium 920 , HPE StorageWorks Ultrium 920
