HPE 20-port Gig-T Expansion MD
Quicklinx: 7BKHWS00 Mfr#: J9548A
Wired / Wireless: Wired
Protocol: Gigabit Ethernet, Fast Ethernet, Ethernet
Form Factor: Plug-in module
Compatibility: PC
Type: Expansion module
£2,434.88 ex VAT
£2,921.85 inc VAT
HP 20-port Gig-T / 2-port 10-GbE SFP+ v2 zl Module for HP E5400/E8200 series zl switches
  • Two open 10-GBE SFP plus transceiver slots
  • 20 RJ-45 autosensing 10/100/1,000 ports (IEEE 802.3 Type 10 Base-T, IEEE 802.3u Type 100 Base-TX, IEEE 802.3ab Type 1,000 Base-T)
  • Media Type: Auto-MDIX
  • Duplex: 10 Base-T/100
  • Base-TX: half or full, 1000 Base-T: full only
2.1 lb. (0.95 kg)
Dimensions (W x D x H)
10.3 x 8.13 x 1.75 in. (26.16 x 20.65 x 4.45 cm)
HPE - expansion module - Gigabit Ethernet x 20
Expansion module
Plug-in module
Ports
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
Auxiliary Ports
2 x SFP+
10Mb LAN, 100Mb LAN, 1GbE
Data Transfer Rate
1 Gbps
HPE 8206, 8206-44G-PoE+/2XG-SFP+ v2, 8212, 8212-92G-PoE+/2XG-SFP+ v2; HPE Aruba 5406, 5406-44G-PoE+/4SFP, 5406-44G-PoE+-2XG v2, 5406-48G, 5412, 5412-92G-PoE+/4SFP, 5412-92G-PoE+-2XG v2, 5412-92G-PoE+-4G v2, 5412-96G
Expansion module
Plug-in module
Ports
Wired
Cabling Type
Auxiliary Ports
2 x SFP+
Data Transfer Rate
1 Gbps
Expansion Slots
2 (total) / 2 (free) x SFP+
20 x 1000Base-T - RJ-45
Compatible Slots
1 x Expansion Slot
HPE 8206 zl Switch, 8206-44G-PoE+/2XG-SFP+ v2 zl Switch, 8212 zl Switch, 8212-92G-PoE+/2XG-SFP+ v2 zl Switch , HPE Aruba 5406 zl, 5406-44G-PoE+/4SFP Rack Shippable zl Switch, 5406-44G-PoE+/4SFP zl, 5406-44G-PoE+-2XG v2 zl, 5406-48G Rack Shippable zl, 5406-48G zl, 5412 zl, 5412-92G-PoE+/4SFP Rack Shippable zl, 5412-92G-PoE+/4SFP zl, 5412-92G-PoE+-2XG v2 zl, 5412-92G-PoE+-4G v2 zl, 5412-96G zl
7BKH C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £14.00
7BKH Aruba SFP Transceiver Module 1000Base In Stock £113.07
7BKH Aruba 10G SFP+ LC SR 300m MMF XCVR In Stock £400.98
Protocol: Fast Ethernet
Protocol: Ethernet
Compatibility: PC
Brand: HPE
Price Range Ex VAT: £1500+
