Your basket is empty
HPE 1TB Dual Port Midline Hot-Swap 3.5" LFF - SAS - 7200 rpm
Quicklinx: 81GSWS00 Mfr#: 461289-001
Serial Attached SCSI (SAS) provides a superior storage solution. With some storage requirements escalating and others becoming more complex, factors such as flexibility, performance, increased reliability, greater density, security, scalability and accessibility are more critical than ever.
SAS Midline hard drives are ideal for servers or external storage for high-capacity, non mission-critical environments with less than 40% workloads requiring economical reliability (about twice that of entry drives) and redundant data paths to the drive, e.g. disk backup, archival, reference, and other highly available applications.
HPE Dual Port Midline - hard drive - 1 TB - SAS
Hard drive - hot-swap
1 TB
3.5" LFF
SAS
Data Transfer Rate
300 MBps
Spindle Speed
7200 rpm
1 year warranty
ProLiant DL160 G6 (3.5"), DL180 (3.5"), DL180 G5 (3.5"), DL180 G5 Special Server (3.5"), DL180 G6 (3.5"), DL185 G5 (3.5"), DL380 G6 (3.5"), DL380 G6 Performance (3.5"), ML110 G6 (3.5"), ML350 (3.5"), ML350 G5 (3.5"), ML350 G5 Base (3.5"), ML350 G5 Entry (3.5"), ML350 G6 (3.5")
1 TB
3.5" LFF
SAS
Performance
Drive Transfer Rate
300 MBps (external)
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x SAS
Compatible Bay
3.5" LFF
Limited warranty - 1 year
HPE ProLiant DL160 G6 (3.5"), DL180 (3.5"), DL180 G5 (3.5"), DL180 G5 Special Server (3.5"), DL180 G6 (3.5"), DL185 G5 (3.5"), DL380 G6 (3.5"), DL380 G6 Performance (3.5"), ML110 G6 (3.5"), ML350 (3.5"), ML350 G5 (3.5"), ML350 G5 Base (3.5"), ML350 G5 Entry (3.5"), ML350 G6 (3.5")
