HPE 1TB 6G SATA 3.5in NHP MDL HDD
Quicklinx: C18TWS00 Mfr#: 801882-B21
Form Factor: 3.5 LFF
Type: Hard drive
Interface Type: SAS
Capacity: 1TB, 1TB
Spin Speed (rpm): 7200rpm
19 In Stock
£93.57 ex VAT
£112.28 inc VAT
Do you have non-mission critical applications that require economical high capacity and reliability hard disk drives? HPE SATA Hard Drives are built for reliability and larger capacity needs for today's non-mission critical server applications and storage environments. These high-capacity drives provide the lowest $/GB, and the best price advantage for non-mission critical applications with low workloads of 40% or less. HPE SATA Hard Drives are available in both Large Form Factor (LFF) (3.5-inch) and Small Form Factor (SFF) (2.5-inch) and ship with a standard one-year warranty. All HPE hard drives pass a rigorous qualification process, which certify that every HPE drive is proven to perform in your HPE ProLiant Server environments. Before final certification, all HPE SATA Hard Drives are optimized for compatibility and functionality, including support of SMART and HPE Systems Insight Manager.
  • HPE Hard Drives Deliver High Performance and Reliability Across HPE Server and Storage Platforms
    HPE Hard Disk Drives (HDDs) are enterprise-class drives for demanding 24x7 data center environments.HPE HDDs are validated and tested with on-going quality monitoring throughout their lifecycle.
  • Enhance Total Server Storage Capacity for Business Critical Workloads with HPE HDDs
    HPE offers highest capacity 20 TB hard drives that are ideal for digital content, bulk storage, cloud and web environments.HPE Business Critical Hard Drives offer high capacity for economic bulk storage.
  • HPE HDDs are Engineered to Deliver High Capacity, Performance, Reliability and Data Security
    HPE HDDs are engineered to maximize total server storage capacity within data center environments.HPE HDDs help prevent unauthorized access to your data with Digitally Signed Firmware.HPE HDDs help simplify the cost and complexity of re-purposing or disposing of drives while protecting data with Instant Secure Erase (ISE) technology.Simplify HDD planning and standardize HDDs across HPE server and storage solutions.Common HPE HDD carriers offer consistency and compatibility across HPE server and storage platforms.
HPE Midline - hard drive - 1 TB - SATA 6Gb/s
Hard drive - internal
1 TB
3.5" LFF
SATA 6Gb/s
Data Transfer Rate
600 MBps
Spindle Speed
7200 rpm
1-year warranty
ProLiant DL180 Gen9, DL20 Gen10, DL20 Gen9, DL60 Gen9, DL80 Gen9, MicroServer Gen10, MicroServer Gen8, ML10 Gen9, ML110 Gen10, ML110 Gen9, ML30 Gen10, ML30 Gen9, ML350 Gen10
1 TB
3.5" LFF
SATA 6Gb/s
Performance
Drive Transfer Rate
600 MBps (external)
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" LFF
Limited warranty - 1 year
HPE ProLiant DL180 Gen9 (3.5"), DL180 Gen9 Base (3.5"), DL180 Gen9 Entry (3.5"), DL180 Gen9 Storage (3.5"), DL20 Gen10 (3.5"), DL20 Gen10 Entry (3.5"), DL20 Gen10 Performance (3.5"), DL20 Gen10 Plus (3.5"), DL20 Gen10 Plus Base (3.5"), DL20 Gen10 Plus Entry (3.5"), DL20 Gen10 Plus High Performance (3.5"), DL20 Gen10 Plus Performance (3.5"), DL20 Gen10 solution (3.5"), DL20 Gen9 (3.5"), DL20 Gen9 Entry (3.5"), DL20 Gen9 Performance (3.5"), DL20 Gen9 Solution (3.5"), DL60 Gen9 (3.5"), DL60 Gen9 Base (3.5"), DL60 Gen9 Entry (3.5"), DL80 Gen9 (3.5"), DL80 Gen9 Entry (3.5"), MicroServer Gen10 (3.5"), MicroServer Gen10 Entry (3.5" LFF), MicroServer Gen10 Performance (3.5" LFF), MicroServer Gen10 Plus Entry (3.5"), MicroServer Gen10 Plus Performance (3.5"), MicroServer Gen10 Plus SMB (3.5"), MicroServer Gen10 Solution (3.5"), MicroServer Gen10 Stockage Collaboration (3.5"), MicroServer Gen8 Performance (3.5" LFF), ML10 Gen9 (3.5"), ML10 Gen9 Entry (3.5"), ML10 Gen9 Performance (3.5"), ML110 Gen10 (3.5"), ML110 Gen10 Entry (3.5"), ML110 Gen10 Performance (3.5"), ML110 Gen10 Solution (3.5"), ML110 Gen9 (3.5"), ML110 Gen9 Base (3.5"), ML110 Gen9 Entry (3.5"), ML30 Gen10 Plus (3.5"), ML30 Gen10 Plus Entry (3.5"), ML30 Gen10 Plus Performance (3.5"), ML30 Gen9 Entry (3.5"), ML30 Gen9 Solution (3.5"), ML350 Gen10 (3.5"), ML350 Gen10 Base (3.5"), ML350 Gen10 Entry (3.5"), ML350 Gen10 High Performance (3.5"), ML350 Gen10 Performance (3.5"), ML350 Gen10 SMB (3.5"), ML350 Gen10 Solution (3.5"), ML350 Gen10 Special Server (3.5"), ML350 Gen10 Sub-Entry (3.5")
Type: Hard drive
Interface Type: SAS
Capacity: 1TB
Capacity: 1TB
Brand: HPE
