HPE 1TB 12G SAS 7.2K 2.5 MDL SC HDD
Quicklinx: CJD6WS00 Mfr#: 832514-B21
Form Factor: 2.5 SFF
Type: Hard drive
Interface Type: SAS
Capacity: 1TB, 1TB
Spin Speed (rpm): 7200rpm
£237.80 ex VAT
£285.36 inc VAT
Do your servers need high-performance SAS disk drives for both your mission-critical and storage driven applications? HPE Server SAS Hard Drives for enterprise and midline applications deliver high-performance solutions for hosting high transaction based applications. They are available in HPE Smart Carrier, HPE Standard Hot Plug Carrier and HPE Non-hot Plug Carrier. HPE Server SAS Hard Drives are available in 2.5-inch Small Form Factor (SFF) and 3.5-inch Large Form Factor (LFF) and come in a variety of capacity points to meet a wide range of requirements supporting enterprise and midline applications. The SAS interface was specifically engineered to deliver high availability where enterprise-class data storage, performance, reliability and data integrity are crucial.
  • HPE Hard Drives Deliver High Performance and Reliability Across HPE Server and Storage Platforms
    HPE Hard Disk Drives (HDDs) are enterprise-class drives for demanding 24x7 data center environments.HPE HDDs are validated and tested with on-going quality monitoring throughout their lifecycle.
  • Enhance Total Server Storage Capacity for Business Critical Workloads with HPE HDDs
    HPE offers highest capacity 20 TB hard drives that are ideal for digital content, bulk storage, cloud and web environments.HPE Business Critical Hard Drives offer high capacity for economic bulk storage.
  • HPE HDDs are Engineered to Deliver High Capacity, Performance, Reliability and Data Security
    HPE HDDs are engineered to maximize total server storage capacity within data center environments.HPE HDDs help prevent unauthorized access to your data with Digitally Signed Firmware.HPE HDDs help simplify the cost and complexity of re-purposing or disposing of drives while protecting data with Instant Secure Erase (ISE) technology.Simplify HDD planning and standardize HDDs across HPE server and storage solutions.Common HPE HDD carriers offer consistency and compatibility across HPE server and storage platforms.
HPE Midline - hard drive - 1 TB - SAS 12Gb/s
Hard drive - hot-swap
1 TB
2.5" SFF
SAS 12Gb/s
Data Transfer Rate
1.2 GBps
Spindle Speed
7200 rpm
75.7 mm x 118.7 mm x 15.6 mm
1-year warranty
Bundled with
HP SmartDrive carrier
Apollo 4200 Gen9; Nimble Storage dHCI Large Solution with HPE ProLiant DL380 Gen10, Medium Solution with HPE ProLiant DL360 Gen10, Small Solution with HPE ProLiant DL360 Gen10; ProLiant BL460c Gen10, DL180 Gen10, DL180 Gen9, DL20 Gen10, DL20 Gen9, DL325 Gen10, DL360 Gen10, DL380 Gen10, DL385 Gen10, DL388 Gen10, DL388 Gen9, DL560 Gen10, DL580 Gen10, DL580 Gen9, ML110 Gen10, ML110 Gen9, ML30 Gen10, ML30 Gen9, ML350 Gen10, XL250a Gen9, XL270d Gen9; StoreEasy 1850; Synergy 480 Gen10
1 TB
2.5" SFF
SAS 12Gb/s
Bytes per Sector
512
75.7 mm
118.7 mm
15.6 mm
Bundled with
Performance
Drive Transfer Rate
1.2 GBps (external)
Seek Time
6.8 ms (average) / 17 ms (max)
Track-to-Track Seek Time
0.5 ms
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x SAS 12 Gb/s
Compatible Bay
2.5" SFF
Limited warranty - 1 year
10 °C
35 °C
HPE Apollo 4200 Gen9 for Google (2.5") , HPE Nimble Storage dHCI Large Solution with HPE ProLiant DL380 Gen10 (2.5"), Medium Solution with HPE ProLiant DL360 Gen10 (2.5"), Small Solution with HPE ProLiant DL360 Gen10 (2.5") , HPE ProLiant DL180 Gen10 Entry (2.5"), DL180 Gen10 SMB (2.5"), DL20 Gen10 (2.5"), DL20 Gen10 Entry (2.5"), DL20 Gen10 Performance (2.5"), DL20 Gen10 Plus (2.5"), DL20 Gen10 Plus Base (2.5"), DL20 Gen10 Plus Entry (2.5"), DL20 Gen10 Plus High Performance (2.5"), DL20 Gen10 Plus Performance (2.5"), DL20 Gen10 solution (2.5"), DL325 Gen10 Base (2.5"), DL325 Gen10 Plus (2.5"), DL325 Gen10 Plus All-NVMe Flash Node for Software Defined Storage (2.5"), DL325 Gen10 Plus for Weka Expansion Tracking (2.5"), DL325 Gen10 Solution (2.5"), DL360 Gen10 Compute Server for Cohesity DataPlatform (2.5"), DL360 Gen10 Network Choice (2.5"), DL360 Gen10 Performance for Cohesity DataPlatform (2.5"), DL360 Gen10 SMB (2.5"), DL360 Gen10 SMB Network Choice (2.5"), DL380 Gen10 All Flash Server for Datera (2.5"), DL380 Gen10 Entry SMB (2.5"), DL380 Gen10 for Cohesity DataPlatform (2.5"), DL380 Gen10 for SAP HANA Compute Block (2.5"), DL380 Gen10 Hybrid Server for Datera (2.5"), DL380 Gen10 Network Choice (2.5"), DL380 Gen10 Network Choice for CTERA (2.5"), DL380 Gen10 Network Choice for SAP HANA Compute Block (2.5"), DL380 Gen10 Server for CTERA (2.5"), DL380 Gen10 SMB (2.5"), DL380 Gen10 SMB Networking Choice (2.5"), DL380 Gen10 Solution (2.5"), DL385 Gen10 Plus (2.5"), DL385 Gen10 Plus Entry (2.5"), DL385 Gen10 SMB (2.5"), DL388 Gen10 (2.5"), DL560 Gen10 for SAP HANA Compute Block (2.5"), DL580 Gen9 SAP HANA Scale-out Base Configuration (2.5"), ML30 Gen10 (2.5"), ML30 Gen10 Entry (2.5"), ML30 Gen10 Performance (2.5"), ML30 Gen10 Solution (2.5"), ML350 Gen10 High Performance (2.5"), ML350 Gen10 SMB (2.5"), ML350 Gen10 Special Server (2.5") , HPE Synergy 480 Gen10 Plus Base Compute Module (2.5")
Type: Hard drive
Interface Type: SAS
Capacity: 1TB
Capacity: 1TB
Brand: HPE
