The HPE OfficeConnect 1950 Switch Series has an intuitive Web-based interface for simple customization of network operation. It supports true-stacking, the aggregation switch supporting up to two devices, while the access switches allowing up to four devices, to be logically administered as a single entity, simplifying administration while supporting greater network redundancy. Models support both rack mounting and desktop operation. These switches have IPv4 and IPv6 operation, with Layer 2 switching as well as Layer 3 static routing. Other features include: link aggregation to boost link performance; VLANs, Access Control Lists, and 802.1X network login for enhanced security; and three versions of Spanning Tree Protocol (STP) for added network resiliency.
Four-high true stacking simplifies administration of multiple devices
Create a single logical managed unit with up to four HPE OfficeConnect 1950 switches. Balance connections across multiple units with Link Aggregation (LACP) for enhanced network resiliency. Stack using affordable Cat 6a, or long distance fiber, or localized DAC cables. -
Intuitive Web browser-based management
Allows for easy customization of the switch even by non-technical users. -
Secure Web-management sessions with HTTPS / SSL
Encrypts and otherwise protects management sessions through HTTP Secure (HTTPS). Prevents snooping of sensitive management information such as passwords. -
SNMPv1, v2c, and v3
Facilitates remote management of the switch, as the device can be discovered and monitored from an SNMP management station. -
Complete session logging
Provides detailed information for problem identification and resolution. -
Dual flash images
Provides independent primary and secondary operating system files for backup while upgrading. -
Port mirroring
Enables traffic on a port to be simultaneously sent to a network analyzer for monitoring. -
Network Time Protocol (NTP)
Synchronizes timekeeping among distributed time servers and clients, keeps timekeeping consistent among all clockdependent devices within the network so that the devices can provide diverse applications based on the consistent time. -
IEEE 802.1AB Link Layer Discovery Protocol (LLDP)
Advertises and receives management information from adjacent devices on a network, facilitating easy mapping by network management applications. -
Limited Command Line Interface (CLI)
Facilitates in the deployment and initial configuration of the unit. Supports troubleshooting actions as well. -
RMON
Provides advanced monitoring and reporting capabilities for statistics, history, alarms, and events. -
Default DHCP client modes
Simplify device deployment. Connect a switch to a network with a DHCP server and the device will obtain its IP address automatically with Plug-and-Play operation.
- HPE OfficeConnect 1950 12XGT 4SFP+ - switch - 12 ports - rack-mountable
- Switch - 12 ports
- Enclosure Type
- Rack-mountable 1U
- Subtype
- 10 Gigabit Ethernet
- Ports
- 12 x 10GBase-T + 4 x 1 Gigabit / 10 Gigabit SFP+
- Performance
- Routing/switching capacity: 320 Gbps , Throughput (64-byte packet size): 238 Mpps , Latency (100 Mbps): 5 µs , Latency (1000Base-T): 5 µs
- Capacity
- IPv4 routing table entries: 512 , IPv6 routing table entries: 256
- MAC Address Table Size
- 16384 entries
- Jumbo Frame Support
- 10KB
- Remote Management Protocol
- SNMP, RMON, HTTPS, CLI
- Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode, QoS, 2MB packet buffer, DSCP support
- IEEE 802.3, IEEE 802.3i, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
- Power
- AC 120/230 V (50/60 Hz)
- 44 cm x 16 cm x 4.4 cm
- 3.66 kg
- Limited lifetime warranty
- Switch - 12 ports
- Enclosure Type
- Desktop, rack-mountable 1U
- Subtype
- Ports
- Performance
- Capacity
- 16384 entries
- 10KB
- Processor
- 1 Cortex-A9: 1.25 GHz
- RAM
- 1 GB SDRAM
- Flash Memory
- 512 MB
- 12 x 10GBase-T RJ-45 , 4 x Gigabit / 10Gbit LAN SFP+ , 1 x console RJ-45 , 1 x management RJ-45
- Power Device
- Internal power supply
- Power Provided
- 800 watt
- Voltage Required
- 75 watt
- Cables Included
- 1 x power cable - 1 m
- Rack Mounting Kit
- Included
- MTBF
- 81.8 years
- CISPR 22 Class A, EN55022, EN 61000-3-3, EN55024, UL 60950, CISPR 22, ICES-003 Class A, IEC 60950-1, EN 60950-1, ISO 7779, EN 61000-3-2:2006+A1:2009+A2:2009, VCCI Class A, EN 61000-3-2:2000, EN 62479:2010, GB 4943.1, EN 300 386 V1.6.1, EN 61000-3-3:2013, EN 55024:2010, EN 55022:2010 Class A, EN 55022 Class A, FCC CFR47 Part 15 B Class A, EN 55032:2012, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
- Software Included
- HP Web browser, HP Intelligent Management Center
- 44 cm
- 16 cm
- 4.4 cm
- 3.66 kg
- Limited warranty - advance parts replacement - lifetime - shipment - response time: next business day , Technical support - phone consulting - lifetime
- 0 °C
- 45 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 5 - 90% (non-condensing)
HPE Premier Flex Network cable 5m Fibre Optic | In Stock | £35.58 |
Aruba SFP Transceiver Module 1000Base | In Stock | £120.95 |
Aruba 10G SFP+ LC SR 300m MMF XCVR | In Stock | £388.30 |
