HPE 1950 12XGT 4SFP+ Switch
Quicklinx: D71SWS00 Mfr#: JH295A
Type: 10 Gigabit Ethernet
Ports: 12
£905.50 ex VAT
£1,086.60 inc VAT
The HPE OfficeConnect 1950 Switch Series has an intuitive Web-based interface for simple customization of network operation. It supports true-stacking, the aggregation switch supporting up to two devices, while the access switches allowing up to four devices, to be logically administered as a single entity, simplifying administration while supporting greater network redundancy. Models support both rack mounting and desktop operation. These switches have IPv4 and IPv6 operation, with Layer 2 switching as well as Layer 3 static routing. Other features include: link aggregation to boost link performance; VLANs, Access Control Lists, and 802.1X network login for enhanced security; and three versions of Spanning Tree Protocol (STP) for added network resiliency.
  • Four-high true stacking simplifies administration of multiple devices
    Create a single logical managed unit with up to four HPE OfficeConnect 1950 switches. Balance connections across multiple units with Link Aggregation (LACP) for enhanced network resiliency. Stack using affordable Cat 6a, or long distance fiber, or localized DAC cables.
  • Intuitive Web browser-based management
    Allows for easy customization of the switch even by non-technical users.
  • Secure Web-management sessions with HTTPS / SSL
    Encrypts and otherwise protects management sessions through HTTP Secure (HTTPS). Prevents snooping of sensitive management information such as passwords.
  • SNMPv1, v2c, and v3
    Facilitates remote management of the switch, as the device can be discovered and monitored from an SNMP management station.
  • Complete session logging
    Provides detailed information for problem identification and resolution.
  • Dual flash images
    Provides independent primary and secondary operating system files for backup while upgrading.
  • Port mirroring
    Enables traffic on a port to be simultaneously sent to a network analyzer for monitoring.
  • Network Time Protocol (NTP)
    Synchronizes timekeeping among distributed time servers and clients, keeps timekeeping consistent among all clockdependent devices within the network so that the devices can provide diverse applications based on the consistent time.
  • IEEE 802.1AB Link Layer Discovery Protocol (LLDP)
    Advertises and receives management information from adjacent devices on a network, facilitating easy mapping by network management applications.
  • Limited Command Line Interface (CLI)
    Facilitates in the deployment and initial configuration of the unit. Supports troubleshooting actions as well.
  • RMON
    Provides advanced monitoring and reporting capabilities for statistics, history, alarms, and events.
  • Default DHCP client modes
    Simplify device deployment. Connect a switch to a network with a DHCP server and the device will obtain its IP address automatically with Plug-and-Play operation.
HPE OfficeConnect 1950 12XGT 4SFP+ - switch - 12 ports - rack-mountable
Switch - 12 ports
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
12 x 10GBase-T + 4 x 1 Gigabit / 10 Gigabit SFP+
Performance
Routing/switching capacity: 320 Gbps , Throughput (64-byte packet size): 238 Mpps , Latency (100 Mbps): 5 µs , Latency (1000Base-T): 5 µs
IPv4 routing table entries: 512 , IPv6 routing table entries: 256
MAC Address Table Size
16384 entries
Jumbo Frame Support
10KB
Remote Management Protocol
SNMP, RMON, HTTPS, CLI
Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode, QoS, 2MB packet buffer, DSCP support
IEEE 802.3, IEEE 802.3i, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
44 cm x 16 cm x 4.4 cm
3.66 kg
Switch - 12 ports
Enclosure Type
Desktop, rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
Performance
16384 entries
Jumbo Frame Support
10KB
1 Cortex-A9: 1.25 GHz
RAM
1 GB SDRAM
Flash Memory
512 MB
12 x 10GBase-T RJ-45 , 4 x Gigabit / 10Gbit LAN SFP+ , 1 x console RJ-45 , 1 x management RJ-45
Internal power supply
Power Provided
800 watt
75 watt
1 x power cable - 1 m
Rack Mounting Kit
Included
MTBF
81.8 years
CISPR 22 Class A, EN55022, EN 61000-3-3, EN55024, UL 60950, CISPR 22, ICES-003 Class A, IEC 60950-1, EN 60950-1, ISO 7779, EN 61000-3-2:2006+A1:2009+A2:2009, VCCI Class A, EN 61000-3-2:2000, EN 62479:2010, GB 4943.1, EN 300 386 V1.6.1, EN 61000-3-3:2013, EN 55024:2010, EN 55022:2010 Class A, EN 55022 Class A, FCC CFR47 Part 15 B Class A, EN 55032:2012, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
Software Included
HP Web browser, HP Intelligent Management Center
44 cm
16 cm
4.4 cm
3.66 kg
Limited warranty - advance parts replacement - lifetime - shipment - response time: next business day , Technical support - phone consulting - lifetime
45 °C
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
D71S HPE Premier Flex Network cable 5m Fibre Optic In Stock £35.58
D71S Aruba SFP Transceiver Module 1000Base In Stock £120.95
D71S Aruba 10G SFP+ LC SR 300m MMF XCVR In Stock £400.98
Ports: 12
Brand: HPE
Price Range Ex VAT: £750 - £1000
