HPE 16GB DDR4 2400MHz CL17 DIMM Memory
Quicklinx: CM69WS00 Mfr#: 836220-B21
Does your server have the memory it needs to perform as its role expands over time? When you choose HPE DDR4 SmartMemory, you get great performance, reliability, and efficiency that provides the compatibility, capacity and bandwidth you need to productively manage your expanding workload with the HPE ProLiant Gen9 server, Apollo Family, Synergy and Blade Systems. The quality and reliability of DRAM are more important now than ever, as data center trends such as server virtualization, cloud computing, the use of large database applications, have all increased the need for higher capacity memory with greater uptime. HPE SmartMemory goes through rigorous qualification and testing processes that unlock extended memory performance features available only with Hewlett Packard Enterprise Gen9 servers. This extensive testing ensures that HPE server memory is completely compatible with and optimized for HPE servers.
  • High Performance
    HPE DDR4 Smart Memory 3200 MT/s provides improvements in bandwidth in comparison to DDR4 2933 MT/s memory modules.HPE DDR4 Smart Memory delivers improvements in latency at 3200 MT/s in comparison to DDR4 2933 MT/s memory modules.
  • High Reliability
    Hewlett Packard Enterprise tests and qualifies HPE DDR4 Smart Memory modules on all HPE server platforms to deliver the highest level of signal integrity.HPE DDR4 Smart Memory prevents unnecessary DIMM replacement and reduces server downtime with advanced memory error detection technology.HPE uses the highest quality materials for its DDR4 server memory, reducing issues that may affect signal integrity and increasing system reliability.HPE provides server memory that performs above industry standards, enabling customers to increase the performance of their servers without having to increase the amount of memory purchased.
HPE - DDR4 - module - 16 GB - DIMM 288-pin - 2400 MHz / PC4-19200 - registered
Memory module
16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL17 (17-17-17)
Dual rank, registered
Voltage
1.2 V
HP 836220-B21
Apollo 4200 Gen9, 4520 Gen9; ProLiant BL460c Gen9, DL120 Gen9, DL160 Gen9, DL180 Gen9, DL360 Gen9, DL380 Gen9, DL388 Gen9, DL580 Gen9, DL60 Gen9, DL80 Gen9, ML110 Gen9, ML150 Gen9, ML350 Gen9, XL230a Gen9, XL250a Gen9, XL270d Gen9, XL2x260w; SimpliVity 380 Gen9; Synergy 480 Gen9
16 GB
Upgrade Type
System specific
HP 836220-B21
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL17 (17-17-17)
ECC
Chips Organization
X4
Voltage
1.2 V
Colour Category
Green
HPE Apollo 4200 Gen9, 4200 Gen9 for Google, 4520 Gen9 , HPE ProLiant BL460c Gen9, BL460c Gen9 Base, BL460c Gen9 Entry, BL460c Gen9 Performance, DL120 Gen9, DL120 Gen9 Entry, DL160 Gen9, DL160 Gen9 Base, DL160 Gen9 Entry, DL160 Gen9 Performance, DL180 Gen9, DL180 Gen9 Base, DL180 Gen9 Entry, DL180 Gen9 Storage, DL360 Gen9, DL360 Gen9 Base, DL360 Gen9 CMS, DL360 Gen9 Entry, DL360 Gen9 High Performance, DL360 Gen9 Performance, DL360 Gen9 Special Server, DL380 Gen9, DL380 Gen9 Base, DL380 Gen9 Entry, DL380 Gen9 High Performance, DL380 Gen9 Performance, DL388 Gen9, DL388 Gen9 Base, DL580 Gen9, DL580 Gen9 Database, DL580 Gen9 SAP HANA Scale-out Base Configuration, DL580 Gen9 SAP HANA Scale-up Base Configuration, DL60 Gen9, DL60 Gen9 Base, DL60 Gen9 Entry, DL80 Gen9, DL80 Gen9 Base, DL80 Gen9 Entry, ML110 Gen9, ML110 Gen9 Base, ML110 Gen9 Entry, ML150 Gen9, ML150 Gen9 Base, ML150 Gen9 Entry, ML150 Gen9 Performance, ML350 Gen9, ML350 Gen9 Base, ML350 Gen9 Entry, ML350 Gen9 Performance, XL230a Gen9 NHP Compute Tray (12G), XL250a Gen9 Accelerator Tray, XL270d Gen9, XL2x260w , HPE SimpliVity 380 Gen9 Node , HPE Synergy 480 Gen9 Compute Module, 480 Gen9 Expanded Storage Compute Module
