HPE DDR4 SmartMemory delivers great performance, reliability, and efficiency. The quality and reliability of DRAM are more important now than ever, as data center trends such as server virtualization, cloud computing, the use of large database applications, have all increased the need for higher-capacity memory with greater uptime.
High Performance
HPE DDR4 Smart Memory 3200 MT/s provides improvements in bandwidth in comparison to DDR4 2933 MT/s memory modules.HPE DDR4 Smart Memory delivers improvements in latency at 3200 MT/s in comparison to DDR4 2933 MT/s memory modules. -
High Reliability
Hewlett Packard Enterprise tests and qualifies HPE DDR4 Smart Memory modules on all HPE server platforms to deliver the highest level of signal integrity.HPE DDR4 Smart Memory prevents unnecessary DIMM replacement and reduces server downtime with advanced memory error detection technology.HPE uses the highest quality materials for its DDR4 server memory, reducing issues that may affect signal integrity and increasing system reliability.HPE provides server memory that performs above industry standards, enabling customers to increase the performance of their servers without having to increase the amount of memory purchased.
- HPE SmartMemory - DDR4 - module - 16 GB - DIMM 288-pin - 2666 MHz / PC4-21300 - registered
- Product Type
- Memory module
- Capacity
- 16 GB
- Memory Type
- DDR4 SDRAM - DIMM 288-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 2666 MHz (PC4-21300)
- Latency Timings
- CL19 (19-19-19)
- Single rank, registered
- Voltage
- 1.2 V
- OEM Manufacturer Equivalent Part Number
- HP 815098-B21, HP 850880-001
- Designed For
- Nimble Storage dHCI Large Solution with HPE ProLiant DL380 Gen10, Medium Solution with HPE ProLiant DL360 Gen10, Small Solution with HPE ProLiant DL360 Gen10; ProLiant DL160 Gen10, DL180 Gen10, DL360 Gen10, DL380 Gen10, DL388 Gen10, DL560 Gen10, ML110 Gen10, ML350 Gen10; Synergy 480 Gen10
- Capacity
- 16 GB
- Upgrade Type
- System specific
- DRAM memory module
- Technology
- DDR4 SDRAM
- Form Factor
- DIMM 288-pin
- Speed
- Latency Timings
- CL19 (19-19-19)
- ECC
- Module Configuration
- 2048 x 72
- Chips Organization
- X4
- Voltage
- 1.2 V
- Designed For
- HPE Nimble Storage dHCI Large Solution with HPE ProLiant DL380 Gen10, Medium Solution with HPE ProLiant DL360 Gen10, Small Solution with HPE ProLiant DL360 Gen10 , HPE ProLiant DL160 Gen10, DL160 Gen10 Base, DL160 Gen10 Entry, DL160 Gen10 SMB, DL180 Gen10, DL180 Gen10 Base, DL180 Gen10 Entry, DL180 Gen10 SMB, DL360 Gen10 All Flash Server for Weka, DL360 Gen10 Compute Server for Cohesity DataPlatform, DL360 Gen10 Low, DL360 Gen10 Network Choice, DL360 Gen10 Performance for Cohesity DataPlatform, DL360 Gen10 Remote Office Branch Office Server for Cohesity DataPlatform, DL360 Gen10 SMB, DL360 Gen10 SMB Network Choice, DL360 Gen10 Solution, DL380 Gen10 48TB Server for Cohesity DataPlatform, DL380 Gen10 96TB Server for Cohesity DataPlatform, DL380 Gen10 All Flash Server for Datera, DL380 Gen10 Entry SMB, DL380 Gen10 for Cohesity DataPlatform, DL380 Gen10 for SAP HANA Compute Block, DL380 Gen10 Hybrid Server for Datera, DL380 Gen10 Network Choice, DL380 Gen10 Network Choice for CTERA, DL380 Gen10 Network Choice for SAP HANA Compute Block, DL380 Gen10 NVMe All Flash Server for Datera, DL380 Gen10 Server for CTERA, DL380 Gen10 SMB, DL380 Gen10 SMB Networking Choice, DL380 Gen10 Solution, DL388 Gen10, DL388 Gen10 Network Choice, DL560 Gen10 for SAP HANA Compute Block, DL580 Gen10, DL580 Gen10 Base, DL580 Gen10 Entry, DL580 Gen10 Performance, ML110 Gen10, ML110 Gen10 Entry, ML110 Gen10 Performance, ML110 Gen10 Solution, ML350 Gen10, ML350 Gen10 Base, ML350 Gen10 Entry, ML350 Gen10 High Performance, ML350 Gen10 Performance, ML350 Gen10 SMB, ML350 Gen10 Solution, ML350 Gen10 Special Server, ML350 Gen10 Sub-Entry , HPE Synergy 480 Gen10 Base Compute Module, 480 Gen10 Compute Module, 480 Gen10 Performance Compute Module, 480 Gen10 Premium Backplane Compute Module, 480 Gen10 Standard BackPlane Compute Module, 480 Gen10 w/o Drives Compute Module, 660 Gen10 Compute Module, 660 Gen10 Premium Compute Module
