HPE 0X2X16 G3 KVM Consolewitch
Quicklinx: CGSNWS00 Mfr#: AF652A
Type: KVM
Ports: 16
£2,389.57 ex VAT
£2,867.48 inc VAT
Knowledge is power with HPE KVM. Looking for a simple and intuitive solution that allows you to access and manage servers in your data center? HPE KVM Analog Console Switches allow you to view and manage up to 256 rackmount servers through a single user interface. KVM Analog Console Switches utilize a local On-Screen Display (OSD) interface, accessed through a rack console such as the HPE LCD8500, that provides intuitive menus for accessing each attached server or serial managed device. HPE KVM Analog Console Switches support an optional USB Remote Access Key that allow you to upgrade to KVM-over-IP functionality, providing remote access and management via the On-Board Web Interface (OBWI). Available in 4, 8 and 16-Port models. Standard rack mounting of the KVM Console Switch will share 1U (1.75-inch) of front panel rack space with the rack console. However, each model can also be mounted in a "zero U" profile by mounting in the side rails of the rack.
  • View and Manage up to 256 Servers through a Single User Interface
    HPE Advanced Analog KVM switches utilize a local On-Screen Display (OSD) that provides access to system-related information such as selected server name, status, power-up test data and configuration menus.HPE Advanced Analog KVM switches support an optional USB Remote Access Key that allow you to upgrade to KVM-over-IP functionality, providing remote access and management via the On-Board Web Interface (OBWI).HPE Advanced Analog KVM switches include Programmable Scanning, a utility that allow you to evaluate system performance by sequentially scanning any or all servers managed through the console switch.
  • 8-Port and 16-Port models with multiple installation and server connection options
    HPE Advanced Analog KVM switches include mounting hardware that support "Zero U" installations on both the side and rear of standard IT racks, saving valuable space within your rack.HPE Advanced Analog KVM switches support a variety of server connections with interface adapters for PS/2, USB, and VT 100 (serial console support), as well as HPE BladeSystems support via the front diagnostics connector.
  • Manageability
    For protection against unauthorized users, HPE Advanced Analog KVM switches provide a password option.Features support for HPE Location Discovery Services (LDS) and Power Discovery Services (PDS) support when connected to an HPE Intelligent Power Distribution Unit (iPDU) and the HPE LCD8500 1U Rackmount Console Kit (HPE Location Discovery Services LCD8500 Kit required).On-Board Web Interface (OBWI) – built in web server providing remote management of the KVM.
  • We have an Advanced Analog KVM switch that's right for your environment
    HPE Advanced Analog KVM switches are designed to be used with HPE servers, storage, and networking products.You can use HPE rack and power products with non-HPE IT equipment; however, when used with Hewlett Packard Enterprise servers, you are able to take advantage of various server and IP-based tools used for maintaining and managing all the equipment in the rack.Don't spend additional budget on extended warranties for your rack and power infrastructure. HPE Pointnext operational services purchased for servers extend to our rack and power infrastructure products such as racks, power distribution units, uninterruptible power systems, and KVM console switches.
HPE KVM Console G3 Switch 0x2x16 - KVM switch - 16 ports - rack-mountable
KVM switch - 16 ports - CAT5 - cascadable
Enclosure Type
Rack-mountable
Subtype
KVM
Ports
16 x KVM port(s)
KVM Users Qty
2 local users
On-Screen Display
43.8 cm x 16.51 cm x 4.36 cm
2.04 kg
ProLiant DL120 Gen9, DL160 Gen8, DL160 Gen9, DL180 Gen9, DL20 Gen9, DL320e Gen8, DL360e Gen8, DL360p Gen8, DL380 Gen9, DL380e Gen8, DL380p Gen8, DL385p Gen8, DL580 Gen9, DL60 Gen9, DL80 Gen9, MicroServer Gen8, ML110 Gen9, ML150 Gen9, ML310e Gen8, ML350e Gen8, ML350p Gen8
KVM switch - 16 ports - cascadable
Enclosure Type
Rack-mountable
Subtype
KVM
Ports
16 x KVM port(s)
KVM Local Users Qty
2 local users
Server Connection Via Twisted Pair
CAT5
Keyboard / Mouse Interface
USB
On-Screen Display
16 x KVM RJ-45 , 1 x management , 1 x cascading RJ-45 , 2 x VGA HD-15 , 4 x keyboard (USB) Type A , 4 x mouse (USB) Type A
Internal power supply
1 x DB-9 to RJ-45 adapter
Rack Mounting Kit
Included
43.8 cm
16.51 cm
4.36 cm
2.04 kg
50 °C
20 - 80%
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
HPE ProLiant DL120 Gen9, DL120 Gen9 Entry, DL160 Gen8, DL160 Gen8 Base, DL160 Gen8 Entry, DL160 Gen8 Performance, DL160 Gen9, DL160 Gen9 Base, DL160 Gen9 Entry, DL160 Gen9 Performance, DL180 Gen9, DL180 Gen9 Base, DL180 Gen9 Entry, DL180 Gen9 Storage, DL20 Gen9, DL20 Gen9 Entry, DL20 Gen9 Performance, DL320e Gen8, DL320e Gen8 Base, DL320e Gen8 Entry, DL320e Gen8 Performance, DL320e Gen8 Special Server, DL320e Gen8 v2, DL320e Gen8 v2 Base, DL320e Gen8 v2 Entry, DL320e Gen8 v2 Performance, DL360e Gen8, DL360e Gen8 Base, DL360e Gen8 Entry, DL360e Gen8 Performance, DL360e Gen8 Special Server, DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 Entry, DL360p Gen8 High Performance, DL360p Gen8 Performance, DL380 Gen9, DL380 Gen9 Base, DL380 Gen9 Entry, DL380 Gen9 High Performance, DL380 Gen9 Performance, DL380e Gen8, DL380e Gen8 Base, DL380e Gen8 Entry, DL380e Gen8 High Performance, DL380e Gen8 Storage, DL380p Gen8, DL380p Gen8 Base, DL380p Gen8 Entry, DL380p Gen8 High Performance, DL380p Gen8 Performance, DL380p Gen8 Special, DL385p Gen8, DL385p Gen8 Dedicated Workload, DL385p Gen8 Entry, DL385p Gen8 Maximized Consolidation, DL385p Gen8 Storage, DL385p Gen8 Storage Centric, DL580 Gen9, DL580 Gen9 Base, DL580 Gen9 High Performance, DL580 Gen9 SAP HANA Scale-out Base Configuration, DL580 Gen9 SAP HANA Scale-up Base Configuration, DL60 Gen9, DL60 Gen9 Base, DL60 Gen9 Entry, DL80 Gen9, DL80 Gen9 Base, DL80 Gen9 Entry, MicroServer Gen8, MicroServer Gen8 Base, MicroServer Gen8 Entry, MicroServer Gen8 Performance, ML110 Gen9, ML110 Gen9 Base, ML110 Gen9 Entry, ML150 Gen9, ML150 Gen9 Base, ML150 Gen9 Entry, ML150 Gen9 Performance, ML310e Gen8, ML310e Gen8 v2, ML310e Gen8 v2 Base, ML310e Gen8 v2 Enty, ML310e Gen8 v2 Performance, ML350e Gen8, ML350e Gen8 Base, ML350e Gen8 Entry, ML350e Gen8 v2, ML350e Gen8 v2 Base, ML350e Gen8 v2 Entry, ML350p Gen8, ML350p Gen8 Base, ML350p Gen8 Entry, ML350p Gen8 Performance, ML350p Gen8 Special Server
Type: KVM
Ports: 16
Brand: HPE
Price Range Ex VAT: £1500+
