Do you need more performance from your sever or platform? HPE SSDs deliver advanced performance and endurance while reducing power consumption for customers with applications requiring high random read and write IOPs performance.
High performance, exceptional reliability, and efficiency for faster business results
HPE SATA Read Intensive Solid-State Drives are ideal for big data analytics, cloud computing, active archiving, database applications, and data warehousing. -
HPE Multi-Vendor SSDs offer longer SKU lifecycles and immediate availability on SATA SSDs
HPE enhanced its extensive SSD portfolio with a Multi-Vendor SSD SKU offering that allows for extended SKU lifecycles, immediately available supply and preferably priced SATA SSDs.
- HPE - SSD - Read Intensive - 960 GB - SATA 6Gb/s
- Solid state drive - hot-swap
- Capacity
- 960 GB
- NAND Flash Memory Type
- Multi-level cell (MLC)
- Form Factor
- 3.5" LFF
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Drive Class
- Read Intensive
- Digitally Signed Firmware
- 7 mm
- 3-year warranty
- Bundled with
- HPE Low Profile Converter
- Designed For
- Apollo 4200 Gen9; ProLiant DL180 Gen10, DL20 Gen10, DL325 Gen10, DL360 Gen10, DL380 Gen10, ML110 Gen10, ML30 Gen10, ML350 Gen10
- Capacity
- 960 GB
- Form Factor
- 3.5" LFF
- Interface
- SATA 6Gb/s
- 7 mm
- Bundled with
Performance
- Drive Class
- Read Intensive
- Drive Transfer Rate
- 600 MBps (external)
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5" LFF
- Power Consumption
- 1.23 Watt (idle) , 2.33 Watt (random read) , 2.33 Watt (random write) , 1.93 Watt (sequential read) , 2.63 Watt (sequential write) , 2.22 Watt (random read/write) , 2.63 Watt (maximum)
- WEEE
- Limited warranty - 3 years
- Designed For
- HPE Apollo 4200 Gen9 (3.5") , HPE ProLiant DL180 Gen10 (3.5"), DL180 Gen10 Entry (3.5"), DL20 Gen10 Plus (3.5"), DL20 Gen10 Plus Base (3.5"), DL20 Gen10 Plus Entry (3.5"), DL20 Gen10 Plus High Performance (3.5"), DL20 Gen10 Plus Performance (3.5"), DL325 Gen10 (3.5"), DL325 Gen10 Base (3.5"), DL325 Gen10 Entry (3.5"), DL325 Gen10 Performance (3.5"), DL325 Gen10 SMB Solution (3.5"), DL325 Gen10 Solution (3.5"), DL360 Gen10 Plus (3.5"), DL360 Gen10 Plus All-NVMe Server for Software Defined Storage (3.5"), DL380 Gen10 Plus (3.5"), DL380 Gen10 Plus Network Choice (3.5"), ML110 Gen10 (3.5"), ML110 Gen10 Entry (3.5"), ML110 Gen10 Performance (3.5"), ML110 Gen10 Solution (3.5"), ML30 Gen10 (3.5"), ML30 Gen10 Entry (3.5"), ML30 Gen10 Performance (3.5"), ML30 Gen10 Plus (3.5"), ML30 Gen10 Plus Entry (3.5"), ML30 Gen10 Plus Performance (3.5"), ML30 Gen10 Solution (3.5"), ML350 Gen10 (3.5"), ML350 Gen10 Base (3.5"), ML350 Gen10 Entry (3.5"), ML350 Gen10 High Performance (3.5"), ML350 Gen10 Performance (3.5"), ML350 Gen10 SMB (3.5"), ML350 Gen10 Solution (3.5"), ML350 Gen10 Special Server (3.5"), ML350 Gen10 Sub-Entry (3.5")
