HP ZR24w 24" Widescreen 1920 x 1200 7ms DVI-D VGA LCD Monitor
HP ZR24w 24 Zoll S-IPS LCD-Monitor
Quicklinx: 6P7VWS00 Mfr#: VM633AT#ABU
HP introduces a new Performance Series monitor, the HP ZR24w, with the extreme visual performance, 8-way comfort adjustments and power-saving features your business demands.
  • Visual Performance
    The ZR24w delivers outstanding visual performance with its S-IPS panel for enhanced color accuracy at ultra-wide viewing angles, 16.7M displayable colors, 1920 x 1200 resolution, 5 ms response time and 3000:1 dynamic contrast ratio.
  • Responsible
    The ZR24w has an 85% efficient power supply, while the chassis is made up of least 25% recycled resin, so you can be confident the ZR24w has the responsible features your business requires.
  • Productive
    The HP ZR24w enables maximum comfort and best visual positioning with an 8-way comfort adjust stand that provides tilt, pivot, swivel and column height adjustability, so you can increase your comfort and productivity throughout the day.
  • Better together
    HP Z Workstations (sold separately) are tested with all HP Performance displays and also feature complimentary industrial design and high efficiency power supplies for a smart and power-efficient workstation solution.
HP ZR24w - LCD monitor - 24" - Smart Buy
LCD monitor - 24"
USB 2.0 hub
Panel Type
S-IPS
Aspect Ratio
16:10
Native Resolution
1920 x 1200 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
400 cd/m²
Contrast Ratio
1000:1 / 3000:1 (dynamic)
Response Time
7 ms
Colour Support
16.7 million colours
Colour Gamut
83%, 72% NTSC
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Voltage
Carbonite
55.6 cm x 23.5 cm x 42.5 cm
8.5 kg
English / United Kingdom
Pricing Type
Promo
Manufacturer Selling Program
HP Smart Buy
Microsoft Certification
Certified for Windows Vista
Environmental Standards
ENERGY STAR Qualified
Plug and Play, CSA, TUV, VCCI, GS, ISO 13406-2, FCC, RoHS, WEEE, ACA, CISPR
3-year warranty
Display Type
LCD monitor / TFT active matrix
Diagonal Size
24"
Built-in Devices
USB 2.0 hub
Panel Type
S-IPS
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.27 mm
Brightness
400 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
83%, 72% NTSC
Response Time
7 ms
Vertical Refresh Rate
61 Hz
Horizontal Refresh Rate
80 kHz
Video Bandwidth
200 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Colour Temperature
9300K, 5000K, 6500K
Controls & Adjustments
Brightness, contrast, colour temperature, clock
OSD Languages
Chinese (traditional), Chinese (simplified), Brazilian Portuguese, English, German, French, Italian, Spanish, Dutch, Japanese
HDCP, anti-glare, 97% NTSC colour gamut, anti-static, 72% NTSC colour gamut
Carbonite
8.5 kg
VGA , DVI-D , DisplayPort , USB 2.0 upstream (Type B) , 4 x USB 2.0 downstream
Mechanical
Tilt Angle
40
Height Adjustment
10 cm
VESA Mounting Interface
100 x 100 mm
1 x USB cable - 1.8 m , 1 x DVI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
Backlight Life
50,000 hours
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
Pricing Type
Promo
HP Smart Buy
Security Slot Type
Kensington security slot
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
95 Watt
Power Consumption Stand by / Sleep
1 Watt
Sustainability Information
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years - on-site
5 °C
35 °C
20 - 80%
