HP introduces a new Performance Series monitor, the HP ZR24w, with the extreme visual performance, 8-way comfort adjustments and power-saving features your business demands.
Visual Performance
The ZR24w delivers outstanding visual performance with its S-IPS panel for enhanced color accuracy at ultra-wide viewing angles, 16.7M displayable colors, 1920 x 1200 resolution, 5 ms response time and 3000:1 dynamic contrast ratio. -
Responsible
The ZR24w has an 85% efficient power supply, while the chassis is made up of least 25% recycled resin, so you can be confident the ZR24w has the responsible features your business requires. -
Productive
The HP ZR24w enables maximum comfort and best visual positioning with an 8-way comfort adjust stand that provides tilt, pivot, swivel and column height adjustability, so you can increase your comfort and productivity throughout the day. -
Better together
HP Z Workstations (sold separately) are tested with all HP Performance displays and also feature complimentary industrial design and high efficiency power supplies for a smart and power-efficient workstation solution.
- HP ZR24w - LCD monitor - 24" - Smart Buy
- LCD monitor - 24"
- USB 2.0 hub
- Panel Type
- S-IPS
- Aspect Ratio
- 16:10
- Native Resolution
- 1920 x 1200 at 60 Hz
- Pixel Pitch
- 0.27 mm
- Brightness
- 400 cd/m²
- Contrast Ratio
- 1000:1 / 3000:1 (dynamic)
- Response Time
- 7 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 83%, 72% NTSC
- Input Connectors
- DVI-D, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Carbonite
- 55.6 cm x 23.5 cm x 42.5 cm
- 8.5 kg
- Localisation
- English / United Kingdom
- Pricing Type
- Promo
- Manufacturer Selling Program
- HP Smart Buy
- Microsoft Certification
- Certified for Windows Vista
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, CSA, TUV, VCCI, GS, ISO 13406-2, FCC, RoHS, WEEE, ACA, CISPR
- 3-year warranty
- Display Type
- LCD monitor / TFT active matrix
- Diagonal Size
- 24"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- S-IPS
- Aspect Ratio
- 16:10
- Native Resolution
- Pixel Pitch
- 0.27 mm
- Brightness
- 400 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 83%, 72% NTSC
- Response Time
- 7 ms
- Vertical Refresh Rate
- 61 Hz
- Horizontal Refresh Rate
- 80 kHz
- Video Bandwidth
- 200 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Colour Temperature
- 9300K, 5000K, 6500K
- Controls & Adjustments
- Brightness, contrast, colour temperature, clock
- OSD Languages
- Chinese (traditional), Chinese (simplified), Brazilian Portuguese, English, German, French, Italian, Spanish, Dutch, Japanese
- HDCP, anti-glare, 97% NTSC colour gamut, anti-static, 72% NTSC colour gamut
- Carbonite
- 8.5 kg
- VGA , DVI-D , DisplayPort , USB 2.0 upstream (Type B) , 4 x USB 2.0 downstream
Mechanical
- Tilt Angle
- 40
- Height Adjustment
- 10 cm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x USB cable - 1.8 m , 1 x DVI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
- Backlight Life
- 50,000 hours
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- Localisation
- Pricing Type
- Promo
- HP Smart Buy
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 95 Watt
- Power Consumption Stand by / Sleep
- 1 Watt
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - parts and labour - 3 years - on-site
- 5 °C
- 35 °C
- 20 - 80%
