HP ZBook Firefly 15 G7 Intel Core i710510U 16GB/512GB SSD 15.6" Windows 10 Professional 674 - bit
Quicklinx: G2DCWS00 Mfr#: 111D9EA#ABU
  • Core i7
  • IEEE 802.11n
Our lightest 15" ZBook provides true mobility for people who push the typical business PC past its breaking point. In the office or in the field, with pro-level performance and a full-size numeric keypad, you have everything to review work and manage projects from anywhere.
  • Windows 10 Pro for Workstations 64
    Work without compromising on performance or security with Windows 10 Pro for Workstations, powered by HP's collaboration and connectivity technology.
  • Intel Core i7 processor
    Run several CPU–heavy programs simultaneously without sacrificing performance with an Intel Core i7 processor.
  • 15.6" Diagonal FHD Display At 250 Nits
    Get clear and sharp visuals in full high definition. Comfortably work without reflections on an anti-glare screen.
  • HP Z Turbo Drive High-speed Storage
    Work without limits in any location with local PCIe storage that's up to 6x faster than SATA SSD, and up to 21x faster than traditional HDD storage.
  • HP Fast Charge
    Ultra-fast recharge takes you from zero to 50% charge in just 30 minutes.
  • HP Collaboration Keyboard
    Launch and manage calls from anywhere using Skype with HP Noise Cancellation and the world-facing third microphone. Shortcut keys, including start/stop call, calendar and screen share, enable efficient and effective collaboration.
HP ZBook Firefly 15 G7 Mobile Workstation - 15.6" - Intel Core i7 - 10510U - 16 GB RAM - 512 GB SSD - UK
Mobile workstation
Operating System
Win 10 Pro 64-bit - English
Intel Core i7 (10th Gen) - 10510U / 1.8 GHz, up to 4.9 GHz / 8 MB Cache
16 GB DDR4 (2 x 8 GB)
Storage
512 GB SSD - NVMe, TLC
Display
15.6" WLED 1920 x 1080 / Full HD
Graphics
NVIDIA Quadro P520 / Intel UHD Graphics
Video Memory
4 GB GDDR5 SDRAM
Input Device
Keyboard, pointing stick, ClickPad
Keyboard
Keyboard Backlight
Numeric Keypad
Integrated Webcam
Bluetooth 5.0, 802.11a/b/g/n/ac/ax
3-cell - up to 14 hours
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
35.95 cm x 23.36 cm x 1.92 cm
1.75 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Limited warranty - parts and labour - 3 years
Mobile workstation
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Intel Core i7 (10th Gen) 10510U / 1.8 GHz
Max Turbo Speed
4.9 GHz
Number of Cores
Quad-Core
Cache
L3 - 8 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
16 GB (2 x 8 GB)
Max RAM Supported
64 GB
DDR4 SDRAM - non-ECC
Speed
2666 MHz
Rated Speed
2666 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
0
Storage
Main Storage
512 GB SSD M.2 2280 PCIe - NVM Express (NVMe), triple-level cell (TLC)
Display
15.6" - IPS
LCD Backlight Technology
WLED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
400 cd/m²
Colour Gamut
72% NTSC
Full HD ultra wide-viewing angle (UWVA) anti-glare, 72% NTSC colour gamut
Keyboard Name
HP Collaboration
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
4 GB GDDR5 SDRAM
Camera
Yes - HD
Video Resolutions
720p
Camera Features
IR camera
Sound
Stereo speakers, HP World Facing Microphone multi-array digital microphone
High Definition Audio
Audio Features
Output: Bang & Olufsen Audio
Input
Keyboard Backlight
Keyboard Layout
Numeric Keypad
Volume control, spill-resistant, ClickPad with gesture support
Communications
Wireless
Wireless Controller
Intel Wi-Fi 6 AX 201
Miracast, dual stream (2x2)
3-cell lithium polymer
56 Wh
Run Time
Up to 14 hours
AC Adapter
Input
Output
65 Watt
Connections & Expansion
Interfaces Details
USB 3.1 Gen 1 , USB 3.1 Gen 1 (charging) , 2 x USB-C (supports Thunderbolt 3) , HDMI , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card)
Software
Software Included
HP Recovery Manager, HP Support Assistant, HP Hotkey Support, HP Performance Advisor, CyberLink Power Media Player, HP Client Security Manager, Absolute Persistence, HP Device Access Manager, HP Mobile Connect Pro, HP JumpStart, HP Noise Cancellation, HP Connection Optimizer, HP Manageability Integration Kit
Security
HP Fast Charge, Pre-boot Authentication, MU-MIMO technology, HP Sure Recover, HP Sure Start Gen 5, HP Sure Sense, HP Secure Erase, HP Sure Platform, HP Sure Recover with Embedded Reimaging Gen 2
Theft/Intrusion Protection
Security Slot Type
Kensington nano security slot
USB-C power adapter
ACPI, CSA, UL, BSMI, GOST, SABS, CCC, FCC, KCC, WEEE, A-Tick, ICES, low halogen, ICCP
Localization
1.75 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
G2DC HP USB-C To VGA Adapter In Stock £23.07
